Old 12-22-2019, 09:40 PM   #26
Andy4639
Old member
Andy4639's Avatar
Talking Re: Fuse panel
Originally Posted by SwitchbladeII View Post
The markings are "easy" to remove. The lower half of my panel was covered with overspray and I knew removing it would remove the markings and it did. On the unpainted section I used alcohol and it cleaned up fairly well. Even without some of the original markings it looks a lot better than it did. I may try to type up stickers to replace but no sure I'm going to do that as it may look worse than without. I know what goes where and correct amperage so don't really need labels
Yea I just used the fuse block picture that has them marked and reinstalled all of them and the flasher's.
I also bought some circuit fuse breakers and installed them in the AC/Heater spots in all my trucks.
Bussmann Division CBF-30 Agc Fuse-30 Amp
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-23-2019, 10:33 AM   #27
HO455
Post Whore
HO455's Avatar
Re: Fuse panel
Once you have cleaned the fuse holders you will need to treat them with something that will prevent the unprotected metal from rusting again. Even humidity in the air will cause them to rust up again. I recommend Corrosion Block, or Copper-seize. The Copper-seize works good but is much messier.
https://learchem.com/products/corrosion-block.html
https://www.amazon.com/Permatex-0912.../dp/B000HBM8HU
RIP Bob Parks.
Old 04-27-2020, 02:34 PM   #28
Johnc2712
Re: Fuse panel
I've never asked a question, so excuse me if I'm doing it incorrectly. Are the add on lugs on the front of the fuse panel fused? I need to add a cigarette lighter, and illumination connection for the light and the light for the heater controls. I would prefer not to have to remove my fuse box to get to the back.
Johnc2712 is offline   Reply With Quote
Old 04-27-2020, 03:21 PM   #29
zosoppp
Re: Fuse panel
The cigarette lighter tab on the face of the panel is always hot and UNFUSED. The panel lights and glovebox taps are fused.
For the cigar lighter wire, it's best to put an inline fuse holder in the wire end that is nearest the fuse box. 25A or less for the fuse (if you are just using it as a power socket and not as a lighter you can probably fuse less than 25 amps).
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 04-27-2020, 03:33 PM   #30
zosoppp
Re: Fuse panel
Adding photos to illustrate the cigar lighter wire with inline fuse holder.
