Old 12-20-2019, 02:05 AM   #26
Greasey Harley
Greasey Harley's Avatar
Re: Got the motor turning
Originally Posted by kidatheart View Post
Which oils are high in zinc?
Rotella has suffecient zink in it. It is technically "diesel oil" and not subject to the same epa regulations as oil for gas engines. Dello is also good.
They're both reasonably cheap.
Lucas, shaffer's, and Joe Gibbs all make break in oil with high zink levels, but it's all fairly pricey.
I run Rotella in my old trucks, and all my motorcycles.
-Russ
Greasey Harley is offline   Reply With Quote
Old 12-20-2019, 11:07 AM   #27
maverickmk
maverickmk's Avatar
-Russ
That's right, I forgot about diesel oil. Good call.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 12-20-2019, 02:59 PM   #28
Daves70
Daves70's Avatar
I would get a can of that STP oil treatment or something like that and pour it literally all over the cam and lifters. That might help when she fires up. It will be fine. I had an old 250 6cyl in a 70 that I dragged out of the bush. It was seized. I poured coke in the cylinders and the next day I had it running. It smoked really bad but after it warmed up the rings started sealing again and it was good. I used that engine for a year and a half while I built another one for my truck.
Daves70 is offline   Reply With Quote
