Old 02-23-2020, 01:44 AM   #26
TA_C10
TA_C10's Avatar
Re: 3 Fan Relay + VA - Diagram
Yep, your right, I see it now... Back to original
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-23-2020, 11:47 AM   #27
dayj1
One other thing regarding your 10 amp circuit that you're using for the relay triggers is to make sure that you use an ignition circuit instead of a battery (always on) circuit. It doesn't matter when you're only using the PCM for fan control. But, when you add the trinary switch, it can turn on the fans when the vehicle is off if the coil power is connected directly to the battery. I've wired a few dozen LS swaps over the years and I've personally had 3 or 4 trinary switches go bad and stick shut. That'll activate your fans and run your battery down.
dayj1 is offline   Reply With Quote
Old 02-23-2020, 12:45 PM   #28
TA_C10
TA_C10's Avatar
Good info, when you look at the GM official diagram it says battery positive. But they didn't use trinary switches either so thanks for that info I'm going to double check and see what I did.
"It's only money".
