02-05-2020, 01:47 AM | #26 | |
Re: DG4 Below eyeline mirrors, replacement elbows and mirror heads
02-05-2020, 01:48 AM | #27 |
Dated glass on some 72 DF2 camper mirrors i had.
Pretty hard to see if can be seen at all in the picture, lower center i cleaned off to show the glass date code. Drivers glass and passenger glass was dated 4-D-2 |
02-05-2020, 01:57 AM | #28 |
Washers are correct. Here's a shot of a 72 mirror I found in Phoenix for a board member several years ago. Same washers that were on my original 69 mirrors.
02-05-2020, 02:51 AM | #29 |
Let's talk elbows...
As Pete mentioned in a post above, the G series vans used similar mirrors at least through 1978 or 1979. The mirror heads were the same. The brackets look similar to the 1972 version but are different otherwise. The elbows are the same in one dimension but shorter in the other dimension. This allows mounting the head so it's closer to the door which makes the mirrors a bit less obtrusive.They are tapped for bolts rather than having studs for the acorn nuts. Those I've rescued are stainless rather than chrome plate so they don't rust and can be polished to a high shine. That's what I have currently on my truck. See picture 1. Other elbow sources (also tapped stainless) include Fords with camper mirrors into the early 90s and, if I recall correctly, some Dodges. Dimensions my vary. Obviously, all these tapped elbows require using a screw-in stud if an acorn nut is desired. I used cutoff stainless bolts. Mirror heads... I've also found these on the Fords as well as Dodges. Some have the letters "da" followed by what appears to be a maple leaf stamp on the stainless. See Picture 2. Some have been offset, some centered. |
02-05-2020, 03:49 AM | #30 |
Good to know some parts are available. Need a set of these for my 72 for resto. Listed on the spid. Long gone when I got the truck. Several sets of mirror holes in the doors.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-05-2020, 08:23 AM | #31 |
Carpe manana
Nuts look great. Good info here.
The screws to attach the mirrors to the door always seemed characteristic for the below eyeline and camper mirrors. I’ll dig one out and post photos when possible. The head has a “P” shaped maker mark.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-05-2020, 10:00 AM | #32 |
Are these mounted to the door with nuts and bolts or plate
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-05-2020, 10:22 AM | #33 |
Carpe manana
Just screwed to the door - no backing plates
02-05-2020, 03:28 PM | #34 |
Pete is correct that the mirrors are just screwed to the doors using hex head sheet metal screws. An early encounter with a parking meter convinced me that this is not the best fastening system. This is one of the not too obvious places where I varied from original on my truck. When I removed a mirror from a late 70s van, I found that GM had refined the fastening system to what is pictured below. They won't rust because they are stainless, won't tear out of the door and are cushioned so the mounting bracket won't damage the paint. The casual observer will never notice. You can see them in use in the 2nd and 3rd pictures in post 19.
https://www.ebay.com/itm/1-4-20-Jack...cAAOSwwfFeJeie Last edited by FirstOwner69; 02-05-2020 at 03:46 PM. |
02-05-2020, 03:44 PM | #35 | |
Equal opportunity joke ofender
Those appear to be G series van mirrors
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-05-2020, 03:53 PM | #36 |
These are the nylon washers I have been using on my mirrors
https://www.mcmaster.com/catalog/126/3426 part #90295A473 Next to the last 3/8 screw size
02-05-2020, 09:52 PM | #37 | |
02-05-2020, 09:53 PM | #38 |
Carpe manana
OEM screws
02-05-2020, 09:55 PM | #39 |
Here is the original sheet metal screws Pete mentioned with the artistic “P” head marking.
They are chrome plated. An internal star washer is used as shown in the picture, these are often missing or fall out when removing, kind of hidden because they are smaller than the screw head. |
02-05-2020, 09:56 PM | #40 |
02-05-2020, 09:58 PM | #41 |
Carpe manana
I need to standardize my washers - I tried a chrome outer washer. Replated OEM acorn nuts.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 02-05-2020 at 10:19 PM. |
02-05-2020, 10:04 PM | #42 |
A picture of my completed mirrors. I have been hesitant to use the stainless elbows because of the hex bolts they come with, im real happy with these high crown stainless acorn nuts, i think its about as good as you can get short of rechroming the original elbows.
02-07-2020, 04:54 PM | #43 |
Does anybody have a better picture or the actual instructions for mounting these mirrors?
As far as i can tell the upper hole is 8 1/4” back and is 3/16 hole size. |
02-07-2020, 06:12 PM | #44 |
Randy
I have searched the assembly manual 3 times and have yet to find the 72 only DG4 mirrors. I did find the ones from 71. Would it not make sense that the top hole would be in the same spot for both mirrors, only measured from different points? In other words the 71 mirror has a measurement of 9.38 but it is on the lower line of the door. If that was brought up to the top line (squared from top edge) it looks to be about the 8.25 you mentioned here because of the taper back of the front edge on the door. Here is a real clear drawing of the 71 DG4 mirrors .
02-07-2020, 06:55 PM | #45 | |
20' Daredevil (Ret)
02-07-2020, 07:46 PM | #46 |
Thanks Richard, for the assembly pic, forgot to ask that. Just got my mirrors in the mail yesterday and the SS looks great, the elbows not so. Glad I bought new ones from NAPA
GREAT THREAD and thank you
02-08-2020, 03:03 AM | #47 |
Thank you Randy! I was given a tip when needing studs quite some time ago. When I needed one I would cut all thread or cut off a bolt. The tip is to use set screws. Come in many sizes, surprisingly long lengths (over two inches) and allen, slot or torx to screw them in. Usually can be had in steel, black oxide or SS.
02-08-2020, 03:41 AM | #48 |
Thats exactly what i did. Worked fine on the mirror end, the other end is s tad short but holding.
02-08-2020, 03:45 AM | #49 | |
The dimensions i posted are from me expanding the picture and guessing...at one time not long ago i had some original doors with dg4 mirrors, im on the lookout for another set to get dimensions. I sometimes forget to look in the assembly manual. |
02-08-2020, 03:50 AM | #50 |
The 71 DG4 Assembly manual pic posted appears to show the off center mirror head as FirstOwner stated earlier, good info, im learning a lot here.
These are good looking truck mirrors which are useable. Funny thing tho, i put a nice set of 72 DG4 mirrors on my crew cab, i liked them but went back to sport mirrors. Im very use to cranking my head to use the sport mirrors and am accustomed to the view they provide. I added a fender mount clip on mirror for towing to the passenger side, kind of 70’s odd-cool. |
