Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-04-2020, 09:59 AM   #1
ecbert
1970 Gear Change / Transmission Swap
Ok, so I'm tired of going 55 mph on the freeway @ 3100 rpm in my medium duty and I wanted to keep it semi-original, so I did a bunch of searching as to the parts I may need.
I figured the best way would be to raise the gear ratio from my current 6.50:1 to some other factory available ratio. So, over the past year or so, I bought a higher geared third member and a Clark 280VO HD transmission to install.
The transmission is NOS and will need nothing, I rounded up the parking brake assembly for it and already found a used shifter assembly off eBay.
I will have to rebuild the third member, pictures of that are going to be coming as I do it.
Currently I just have the two parts shown and I have not torn anything out of my truck yet. The process of rebuilding and doing the swap is just starting, so here goes...
2018 Silverado 6.2 1500 Crew Cab
2011 12 Passenger G3500
1969 369 Nova
1967 Chevelle SS 396
1970 GMC 5500
1991 V3500 Single RR Wheel Gen 6 496 / 4L80E
ecbert is offline   Reply With Quote
