02-11-2020, 11:12 PM | #26 |
Re: Wheel hop under braking
I'm thinking that a pair of simple traction bars (that someone else suggested) that connect and pivot at the same point the front spring bolts are so you don't cause a spring bind may be the easy cure.
Or maybe a torque arm that bolts to a few of the bolts on the third member and runs up and pivots at the same point the front U joint is ala Camaro of a few years ago. Basically going back to a torque tube without a tube.
02-15-2020, 03:18 PM | #27 |
Master cylinder - $33
Wilwood proportioning valve - $46 Misc fittings, brake line and fluid - $35 Amount invested in the collective knowledge base here to diagnose the problem - let’s keep that quiet for the wives’ sake Knowing it’s plumbed right - I can sleep at night The entire setup was plumbed backwards including the proportioning / brake switch valve. It now brakes with no hop / rear lockup. Traction Master keeps promising to send me a drawing but nothing yet. Stay tuned.
1953 GMC 100 1956 Studebaker - Chevy 350 |
