Old 02-11-2020, 05:18 PM   #26
Grumpy old man
Grumpy old man's Avatar
Re: Front disc brakes question
Originally Posted by weq92f View Post
Grumpy,
A little off topic here but...What is your method of painting those rotors and keeping the paint off the friction surfaces?
Thanks,
-klb
I use wax and grease remover and then mask off the disc friction faces , Then I use High temp caliper paint . I works for me .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-11-2020, 10:02 PM   #27
Trash
Trash's Avatar
Thanks Grumpy, Appreciate the parts list. I also have a 67. Going to paint the rotors as soon as the weather warms up. Got’em from Summit, and had some slight shipping damage so they sent me another set. Shipper never picked up the damaged ones.
Trash is offline   Reply With Quote
Old 02-14-2020, 10:16 PM   #28
03BlkZ
Awesome parts list! This should help me tremendously. Is the only way to drop the front of the truck with drop spindles? I have see 2 inch drop springs and assumed they were used to drop with stock spindles. If I get drop spindles do I just use factory height springs?
03BlkZ is offline   Reply With Quote
Old 02-15-2020, 06:43 AM   #29
Andyking1203
Is it possible to use the stock spindles, (70 drum brakes). With stock 71/72 disc brake setup? Thanks
Andyking1203 is offline   Reply With Quote
Old 02-15-2020, 01:59 PM   #30
67C10Step
67C10Step's Avatar
You cannot use a drum brake spindle in a disc brake swap. If you have access to 71/72 spindles you will need ball joints for 71/72 and be good to move ahead. I did my first disc brake conversion when I was 20 but I got everything out of the 72. That was 30 years ago now.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-15-2020, 08:21 PM   #31
Andyking1203
Ok, thanks.. that's pretty much what I figured
