03-11-2020, 09:55 PM | #26 | |
Roto Reuter thats the name...
Re: PCM help and monitoring water temp and oil pressure
Thanks for the vote of confidence for the wiring. I've started taping some of the leads. I'm sure I'll have some questions for you guys along the way.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-11-2020, 10:04 PM | #27 |
My PCM harness did not have a connection for the factory oil sender, nor was there a sender anywhere. The tapped hole at the back of block was empty with nothing installed. I used that location to install the DD oil pres sender. I have no idea what the factory sender or plug even looks like for this 5.3L. Lol. Since there was no option in my harness I assumed I was supposed to use the DD oil sender. I also was unaware of the option to locate it at the oil filter. Had I known that I think I would've used that location instead.
03-11-2020, 10:58 PM | #28 | |
03-12-2020, 03:49 PM | #29 |
So is the TCC wire the one labeled "Brake Switch" in the picture in post #5?
03-12-2020, 03:57 PM | #30 |
So I ordered the Dakota Digital BIM-01-2. With that I should not need to install the additional DD water temp sender correct? Factory water temp sender in DS head will be adequate?
Also, looking at the pictures in Post #5 of wires from my Tilden harness, do I only need to connect the "12V switched" and "Brake Switch" wires?
03-12-2020, 04:50 PM | #31 | |
03-12-2020, 07:36 PM | #32 | |
03-12-2020, 09:25 PM | #33 |
Ok so this might be a stupid question, but in my post #5 picture... is the "12V Switched" wire get connected to 12V, or is it already a 12V switched line? This is how bad I am with this stuff. I just want to make sure that on the LS swap brake switch that I'm not supposed to connect the "Brake Switch" wire to the one terminal and the "12V Switched" to the other terminal.
03-12-2020, 09:59 PM | #34 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-12-2020, 10:11 PM | #35 | |
03-12-2020, 10:26 PM | #36 |
03-12-2020, 10:41 PM | #37 |
Since it doesn't say anything else, I would say you are right. You will however need to add the 12v switched wire to the other side of the brake switch for the TCC lock up.
03-13-2020, 11:38 AM | #38 | |
Another point I have though, is that I also have a fuel pump wire, which I assume to be power for the fuel pump? It's an extremely small gauge wire and nothing like the leads coming off of my fuel pump. Not even close. Is that OK?
03-13-2020, 12:39 PM | #39 |
The fuel pump wire is probably a trigger for a relay
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-13-2020, 01:19 PM | #40 |
What leads me believe that it's not some sort of trigger wire is that it's an extremely long wire. Reaches all the way to the back of the truck. Maybe these pictures will help? Then someone can help me understand.
Here are the relays and fuses provided with my harness.
03-13-2020, 06:01 PM | #41 |
Hey Dan,
Since I only built my own harness hard for me to say but looking at the harness you have and if it came with the pictures shown I would assume that the wire for the fuel pump is probably a #12 wire minimum and long enough to reach a in-tank fuel pump. I would say that's the supply not the trigger. The fuel pump trigger was a #18/20 gauge green wire from the ECM. That harness should have these connections to the harness the system grounds, constant 12+ and switched 12+, and these to be terminated at there locations brake pedal wire, tach wire, fuel pump supply, high and low fan supply. oh and Check engine light!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 03-13-2020 at 06:09 PM. |
03-13-2020, 07:37 PM | #42 | |
For the "12v switched" you want to pull from a power source that is dead when the key is off, hot with the key on. I think it has to be hot when the key is in the start position too so watch that. |
03-13-2020, 07:51 PM | #43 | |
03-13-2020, 08:00 PM | #44 |
I see in post #23 you show the terminals labeled on the brake switch. Is the one that says PCM the TCC wire?
03-13-2020, 08:04 PM | #45 |
Sorry guys. I hadn't read through the entire thread before I asked that.
03-13-2020, 08:06 PM | #46 |
Sorry guys. I didn't read through the entire thread before I asked the question
03-13-2020, 09:22 PM | #47 | |
03-13-2020, 09:24 PM | #48 |
OK so here's what I've learned today: I was able to reach Tilden. The ring terminal for the alternator is the constant hot. The wire labeled "12V Switched" needs to be connected to a 12V switched source (and it's not already a 12V switched wire). The fuel pump wire is not a trigger but the supply for the fuel pump. Tilden said it's not a problem that the supply wire is a smaller gauge then the fuel pump.
03-14-2020, 12:10 PM | #49 | |
This only kind of works. Generally the resistance is off by enough to only give a vague reading of what the engine temperature actually is. You're usually best off using the sender made for whatever gauge you are using.
03-14-2020, 05:39 PM | #50 |
Make sure your 12 volt switched has 12 volts with the key in the start and run position. The brake light switch needs two set of contacts. One for the normal brake light operation and for the torque converter lock up. I typically use a 2002 Camaro switch for an automatic.
