#26 |
Re: Need some brake help, please...
So, '78 calipers are what I need to go with, it sounds like. I'll add that to my notes for future reference. Are the banjo bolts still the same size for the '78 calipers (7/16")?
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
#27 | |
My truck's 454 BBC is so cammed up it doesn't make much vacuum.. I needed something that would work well under low vacuum conditions.. Here's the link to the conversion kit I used: https://www.summitracing.com/parts/sum-760197 I see they've reduced the price approximately $30 since I bought mine... Also, I see they've dropped the proportioning valve from the kit.. I don't have a part # for it, just tell them you want the one that goes with Disk/Drum truck applications.. Last edited by RustyPile; 04-09-2020 at 04:10 PM. |
#28 | |
Before everybody gets the wrong idea, I'm not saying the '78 calipers will necessarily give you better brakes.. What I am saying is cover all the bases, do quality work using premium parts, always machine the friction surfaces .. Take no shortcuts and you will have good brakes. |
#29 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#30 | |
#31 |
Definite big thanks to RustyPile for the info.
I'll be putting a new power booster and hoses soon. I'll follow your directions to the letter. I'm going from manual to power brakes, just to help out my old legs get 'er stopped.
1971 C-10 307 3OTT |
#32 |
Thanks all you guys for the vote of confidence.. I'm just glad to help you guys...
