Old 05-29-2020, 12:10 AM   #26
Chvy2NV
Re: Trinary Switch Integration with Dual Fans
subd... im not ready to do this yet but thanks for the info.. Im lost with all this..
Chvy2NV is offline   Reply With Quote
Old 05-24-2021, 04:36 PM   #27
trobert3
Originally Posted by 87chevy.com View Post
Otjer option you simply install the factory high side pressure sensor and wire the 3 wires to ecu and no need for resistors or anything... then operates like factory
I have a 08 express van e38 computer and engine stand alone harness, I would like to know which 3 wires from ECU goes to the high pressure switch?
trobert3 is offline   Reply With Quote
Old 05-24-2021, 07:33 PM   #28
ls1nova71
ls1nova71's Avatar
X1 pins 12, 13 and 34.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-24-2021, 08:35 PM   #29
trobert3
Ok, Thanks for the reply, any order that they need to be wired to the sensor .
Old 05-25-2021, 10:26 AM   #30
ls1nova71
ls1nova71's Avatar
The sensor plug is numbered 1-3, pin 1 tan wire goes to pin 13 on the ECM, pin 2 gray wire goes to pin 34 and pin 3 orange/black wire goes to pin 12.
Old 05-25-2021, 11:22 AM   #31
trobert3
Thank you LS1nova.
Old 05-26-2021, 07:34 PM   #32
trobert3
[QUOTE=trobert3;8924709]Thank you LS1nova.
Old 05-26-2021, 07:43 PM   #33
trobert3
Found wires and plugged them into sensor, still no fans with ac turned on. System is not fully charged could that be the reason or does it have something to do with the Tuner?
Old 05-27-2021, 09:18 AM   #34
Rich84
Rich84's Avatar
Fully charge the system. If I recall correctly the compressor has to be on for the fan to run. It's been a while though.
Rich84 is offline   Reply With Quote
Old 05-27-2021, 12:42 PM   #35
dayj1
Rich84 is right, the AC system needs to be charged. But, if you're expecting the fans to come on when you turn the AC on, it doesn't work that way. The fans come on as needed based on pressure in the AC system.
With that being said, I thought I read where you had an '08 ECM (Gen IV). I don't believe you will be able to get the fans working with just the pressure transducer. You're going to need a way to get a message on the CAN bus to let the ECM know that AC is being requested (the pressure transducer alone worked for a few select Gen III OS variants) but not Gen IV. Of course this type of thing is subject to change as HP Tuners and other tuning software advances and adds patches over time.
dayj1 is offline   Reply With Quote
Old 05-27-2021, 06:20 PM   #36
nsb29
nsb29's Avatar
My motor is out of a 09 G8 it uses a pressure switch and a brinary switch. The fans are wired using three relays, When I turn the a/c on I have low speed fans almost right a way. high speed comes on in stop and go traffic and no fans on the highway but like previously stated your system Must be completely charged
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 05-27-2021, 08:43 PM   #37
trobert3
Old 05-27-2021, 08:46 PM   #38
trobert3
Thanks for the input everyone, I’m still looking for a way to make this work.
Old 05-28-2021, 10:01 AM   #39
First c10
First c10's Avatar
I have an 08 gen 4 and the only way to get the ac to work like stock is to get the info on the canbus system. With aftermarket ac setup(old air products) I used the 3 relay set up with 2 fans highspeed and lowspeed. I connected my high speed fan wire (can’t remember the color) from my pcm to the relay and tied the trinary switch into it also. No problems with pcm checks and when I turn ac on and the pressure gets to it’s closed contact setting on the trinary switch one fan comes on full speed. When my water temp gets to my low speed setting it turns on the other fan to high speed. But when ac is off my system operates normally low speed high speed. Hopefully it makes sense.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-28-2021, 12:44 PM   #40
trobert3
Thanks for the info First c10, by chance are you able to draw a diagram of how you did the wiring. I’m not good a wiring again thanks!
Old 05-29-2021, 12:38 AM   #41
First c10
First c10's Avatar
I am out of town till next weekend. I will look for my schematic I made when I get back.
GO GO!!!
Old 05-29-2021, 07:55 AM   #42
trobert3
Ok , Thanks
Old 05-30-2021, 07:55 PM   #43
nsb29
nsb29's Avatar
if your using a pressure transducer you run a brinary switch not a trinary this could be your problem I made that mistake and nothing worked
