#26 |
Re: My 1970 2wd Blazer 12 year project almost done
just trying to figure out your engine angle as well as what trans you used and how much of a spacer you had to use for trans mount if you have any pics that would be great. thanks
#27 |
If I remember correctly I used dirty dingo engine mounts and a CCP trans cross member. plenty of room the only place I was close on was the steering shaft between the frame and headers because I’m running the No Limit front crossmember with the rack and pinion setup.
#28 |
![]() Join Date: Oct 2001
Looks like you did a lot of cutting on that windshield frame, it cleaned up nicely.
Are you gonna run vent window's?
Things happen for a reason! |
#29 |
No I do not plan on running the vent windows I plan on running a 1 piece window if I run any at all.
#30 |
front bumpers on hopefully get around to the rear week
#31 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
NICE!! Looks good..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#32 |
Very nice clean restomod with lots of thought in your impressive build.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#33 |
![]() Join Date: Jan 2004
Gonna say it again, very, very nice ! I'd also say worth the wait.
#34 |
Very nice looking Blazer. I wish I would’ve gone with a LS motor. What front suspension components are you using?
Posted via Mobile Device |
