Old 05-19-2020, 10:37 PM   #26
Mike C
Mike C's Avatar
Re: May have finally sorted my less than stellar brake performance...
Thanks for posting all of your results for the rest of us to follow along.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-20-2020, 08:25 AM   #27
jjzepplin
jjzepplin's Avatar
Hydro boost is run from the power steering pump right? I think I read on here somewhere that the LS based steering pump has a bit too much pressure for our old gear box's. If that is true then a hydro boost setup would be ideal here right? Maybe a question for another thread. BTW that is a nice looking LS you have there sir! I had to look twice. I am going back for a third. What AC bracket did you use for the Sanden?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-20-2020, 09:23 AM   #28
FLYNAVY30
Thank you sir! Its a work in progress, but I've tried to run everything as cleanly as possible. The entire accessory set up is the Holley LS high mount....not particularly cheap, but they make nice stuff. Eventually I'd like the pull the motor, clean it up, paint it orange, and then install the extra set of '64 Corvette finned valve covers I have stashed away to give it the full SBC treatment.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 07-03-2020, 07:53 AM   #29
FLYNAVY30
Wanted to update this thread for those following along...I swapped my brake pads out for the Wilwood "E compounds". They have a slightly higher coefficient of friction across the temp. range than the BP-10 pads that came with the calipers. The combo of the new brake booster and the new pads is perfect! Pedal feel is soft and linear, much like a modern car, but the braking force is excellent. In a panic stop from 60, it brakes about the same as my 2016 4runner, with the fronts just barely hitting lock up, with no lock up in the rear.
At the end of the day, I think the changes were definitely worth the effort and a viable solution for those with low vacuum motors.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 07-03-2020, 08:18 AM   #30
jjzepplin
jjzepplin's Avatar
Good to hear! Now it has GO and STOP! I also want to install some older style covers. I have a pair of 69 finned covers. I was thinking of hiding the coils with them. Not sure. I have always been skeptical of pads making a difference. I had the chance to buy some Brembo pads for my foreign car that just happened to need them. They were on a closeout for $5. I could not resist. I had two of the same exact cars and just did the brakes on one with stock stuff. The Brembo pads were fabulous! It stopped so fast that I was worried the airbag would deploy. Good job on the brakes!
Old 07-05-2020, 08:55 PM   #31
Mike C
Mike C's Avatar
Great news. I used to be a naysayer with pads making a difference, but I am no longer myself.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 07-06-2020, 08:29 PM   #32
iriereggaeman
iriereggaeman's Avatar
I went the HydroBoost route as well. I'm really happy with the outcome. Here's a link to that discussion, with some pictures: http://67-72chevytrucks.com/vboard/s...d.php?t=749153
iriereggaeman is offline   Reply With Quote
