05-18-2020, 04:08 PM | #26 |
Re: Drop set ups and wheel combos!!
On the 10" rim your gonna need to go with a 5" BS or you'll get tire rub, this is a 295/50 on the 10" rim with 5" BS.
05-18-2020, 04:43 PM | #27 |
05-18-2020, 04:47 PM | #28 | |
79 Chevy 2wd BIG10 350 TH400 |
05-18-2020, 04:53 PM | #29 | |
https://www.eatondetroitspring.com/
05-18-2020, 05:20 PM | #30 | |
I agree with SCOTI though, it would be hard to talk me into doing just one leaf when there was a failure already.
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
05-18-2020, 05:23 PM | #31 | |
The BS on the fronts may lead to issues with drop spindles as well since they are 3.75" instead of 4". 4" is damn close with 15's with 2.5" spindles, 3" spindles are a no-go. Those wheels look sick!
05-18-2020, 06:06 PM | #32 | |
05-18-2020, 06:26 PM | #33 |
This fellah on here has -45mm offset which is about 3.8” BS and should give me a bit more room and 295s. Think I’m just gonna send it and see what it looks like lol
05-18-2020, 06:27 PM | #34 |
05-18-2020, 08:03 PM | #35 |
I am still trying to talk myself into it lol
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
05-18-2020, 10:02 PM | #36 |
05-19-2020, 05:53 AM | #37 | |
I'm not exactly looking to fill the gap just thinking it will look a little better if it's a little bit lower. I should have done it from the beginning but that's not the look I wanted at the time
05-19-2020, 08:04 AM | #38 | |
05-19-2020, 12:32 PM | #39 | |
05-19-2020, 09:09 PM | #40 |
I'd love to help but my truck is all tore apart at the moment. Front clip, engine, and transmission are out!
05-19-2020, 09:25 PM | #41 |
05-21-2020, 01:14 PM | #42 | |
Let me know if you want any other angles of measurements, I'm happy to help. Same rear specs as Loco, just not near as clean as his!
05-21-2020, 03:04 PM | #43 |
Thanks man! Get em mounted today and gonna install this evening. I'll report back. gonna be close. based on current wheel and tire set up and measuring and the new wheel and tire set up on the tire calculator it's gonna be really close. May look into rolling the inside of my fenders if it makes sense. Thanks again man!
05-21-2020, 04:25 PM | #44 |
No it would need a good bit of drop for that.
05-24-2020, 02:57 AM | #45 |
05-25-2020, 07:20 PM | #46 |
