Old 07-21-2020, 11:52 PM   #26
Ptjsk
Re: Been a long road but it's running
[QUOTE=
Looks like your builder knew to stay away from the COMP lifters and put Howards in your motor. I didn't and have quite a bit of lifter noise as a result. I suspect yours is much quieter than mine.
-klb[/QUOTE]
Nothing but trouble with COMP lifters on the last two motors built.
I will never go with COMP again! Howards have been good!
Pat
Ptjsk is offline   Reply With Quote
Old 07-22-2020, 01:21 AM   #27
Greasey Harley
Greasey Harley's Avatar
Is the dust cover on your driveline rubbing on your carrier bearing?
That can make a hell of a racket under load and quiet right down when you let off.
sound carries up the drive line, and sounds like it's coming from up front.
Easily cured by loosening the bearing and moving it back 1/32".
just a thought.
Hope you figure it out.
-Russ
Greasey Harley is offline   Reply With Quote
Old 07-22-2020, 10:34 AM   #28
Boog
laying low
Boog's Avatar
Good to hear you have found the source of the noise. Maybe a starter shim will clearance it enough?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-22-2020, 12:44 PM   #29
Greasey Harley
just a thought.
-Russ
Guess I din't read all the way through that post very well.
Glad you figured it out.
Old 07-23-2020, 10:21 PM   #30
drink2mny
drink2mny's Avatar
Thanks for the replies guys.. so I took the mini starter out and had a machinist friend take about an 1/8 off.... No noise and sounds great now that I can focus on the motor instead of the noise... Next up is installing the grill and some body mounts from Wes....
Support The Board
drink2mny is offline   Reply With Quote
