10-22-2020, 03:26 PM | #26 |
Re: QA1 Coil Over System
Also, there's an episode of hot rod garage where they install a full kit. And check out lucky's garage/lucky costa on YT. He has an awesome beater C10 he did the QA1 to. Nice truck!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-22-2020, 04:45 PM | #27 | |
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-23-2020, 08:33 AM | #28 |
bigmac73,
Yes those are standard sizes, not metric. I have a 75 steering box with a 72 tilt column. they bolted right up and I did have to cut the shaft to length. The original steering shaft was from the 69. Hope this helps. Wally |
10-25-2020, 05:17 PM | #29 |
Hey Speedtacer, I had the western chassis heavy duty 2 piece bolt in c notch and I just trimmed it to mate up to the QA1 coil over mounts the welded them together. Turned out decent.
10-25-2020, 07:22 PM | #30 |
