Old 10-08-2020, 09:25 AM   #26
ewoody625
ewoody625's Avatar
Re: 4L60E Trans only shifts 2 and 3
Originally Posted by ls1nova71 View Post
OK, so now we're getting somewhere. Do you have 12v on both sides of that fuse? I would think you wouldn't since you did a continuity test on the wire. If you do have power there, then you almost have to have a break in that wire somewhere between the fuse and the trans plug. It's possible that by moving the wires around to test them, it's making contact again however. Have you tried to drive it again? If the short is intermittent, then your best bet is going to be to replace the wire from the fuse to the trans plug since finding the short in the harness with it in the truck will be pretty difficult.
I have half of the wiring out/disconnected. I'll continue to trace the wire back and see which one it is. There are 4 pink wires going to that 10a fuse. I will also check to see how many volts I have there at the fuse.
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 10-08-2020, 02:35 PM   #27
ewoody625
ewoody625's Avatar
I have 12.6 volts on the left side of the fuse and 0 on the right.
Eric
Old 10-08-2020, 03:51 PM   #28
ewoody625
ewoody625's Avatar
I'm still tracing this pink pin E wire but I've gone past where they split off to go to the fuse block. So this wire has to go to the ecm. It goes to pin 63 on the green ecm plug.
Eric
Old 10-08-2020, 06:15 PM   #29
ls1nova71
ls1nova71's Avatar
You've found your problem right there. If you have power on one side of the fuse but not the other, then either the fuse is blown or its not making a good contact in the fusebox. Fix that and you should be good to go.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-08-2020, 06:34 PM   #30
ewoody625
ewoody625's Avatar
Wow.... I feel like an idiot lol. It looked good when I checked it before. I just looked at it again and it's blown. Well now I need to replace that fuse and get everything hooked back up and see if I'm back in business. Thanks for guiding me along.
Eric
Old 10-08-2020, 06:38 PM   #31
ls1nova71
ls1nova71's Avatar
If you have the harness out, Double check it for any bare wires. You need to find the cause of the blown fuse.
Old 10-09-2020, 08:24 PM   #32
ewoody625
ewoody625's Avatar
It's shifting now. I still have a flashing check engine light but no codes. I'll have to keep an eye on that. Thanks for the help!
Eric
Old 11-19-2020, 03:11 PM   #33
Duck1
I have 10.6v at the pink wire on the big round trans plug. That is what I am currently tracing back to see where my voltage drop is coming from. I do not have the tcc wire hooked up, I was told that is optional. To clarify, the tcc gets power from the brake switch? Or it goes to the brake switch and to a power source? I'm at the end of my rope on this. Ready to pull it all out and put my 350 back in. I appreciate the information.
And spend money on a drive shaft. Worst gas mileage. Instead of fixing the problems
Duck1 is offline   Reply With Quote
Old 11-19-2020, 07:10 PM   #34
ls1nova71
ls1nova71's Avatar
