Old 12-19-2003, 12:41 AM   #26
walker
walker's Avatar
The tests are going to tell you where your coolant is going. The compression test will tell you if you have a blown head gasket by low numbers on one or adjacent cylinders. The stand up test will tell you if you have a crack in your cylinder head by blowing air through the crack and into the coolant. The last test is head gasket and head crack test, as bubbles going from the cylinders will bubble up through the neck of the radiator. If these tests come out good you could have a leaking intake manifold. The cooling system pressure test may give you some indicator of where the water intrusion is by leaving water in the cylinders or in the lifter valley( you can check that by removing the dist.
Find the trouble for sure before you tear into it or you may do unneeded work, or you may do the work and find out you didn't fix the problem.
My own case, it turned out that I had a cracked head. So I replaced the heads. Still had water, so I redid the tests. Tore it all down again, turned out I also had a cracked block, in between the #3 and #5 cylinders at the head bolt hole. If I assumed it was a manifold gasket I would have had to dig into it three times. It was bad enough doing it twice, but that could have fooled many people.
BTW anyone wants a set of camel humps with a crack under one exhaust seat let me know.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 12-19-2003, 12:45 AM   #27
junkyardjohn
junkyardjohn's Avatar
SH!T.... DON'T GET ALL EXCITED...... SOUNDS LIKE AN INTAKE GASKET TO ME. ALL YOUR COMPRESSION NUMBERS SOUND GOOD. WHEN YOU TEAR YOUR BLOCK DOWN TO REBUILD IT, HAVE IT SONIC TESTED BEFORE YOU DO ANYTHING TO IT. THIS WILL TELL YOU HOW THICK YOUR CYLINDER WALLS ARE, BUT CHANCES ARE PRETTY GOOD YOU'LL JUST HAVE TO PUT A INTAKE GASKET ON IT, AND DRIVE FOR MANY MORE MILES. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
