Old 12-28-2020, 11:10 PM   #26
kipps
Re: radiator selection
Originally Posted by kev2809 View Post
easy for u truck guys
You mentioned that you were working with a 67 Suburban. Isn't that sitting on the same chassis as a pickup? Is the crossmember arranged different on the 67-72 trucks, compared to the squarebody's? A squarebody is all I've had experience with.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 12-28-2020, 11:36 PM   #27
mongocanfly
Post Whore
mongocanfly's Avatar
Kipps... the IH was way off...not even close to center...the C30 wasnt as bad but it didnt line up in the factory shroud..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-29-2020, 05:05 AM   #28
kev2809
low n' slo
kev2809's Avatar
isnt the cross member riveted in? either way, it seems like a tight squeeze to get that cross member out and drill new holes under there with the body on
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-29-2020, 06:06 AM   #29
ls1nova71
ls1nova71's Avatar
Manual transmission crossmembers are riveted in, automatics are bolted in. Drilling new holes isn't that hard on the bottom of the frame, but the top ones can be tough. A lot of people don't bother bolting it at the top though.
If you have a manual transmission crossmember you will have to remove it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-29-2020, 09:22 AM   #30
kipps
I pulled and reinstalled two transmissions on these classic trucks. Both were manual. A 1987 chevy 4wd, and a 1981 Ford 2wd. The chevy was missing the extra brace pieces that went to the top flange on the frame rail. I didn't worry about it. The Ford had those braces, but I don't remember if I bothered to reinstall them or not.
Just drill new holes in the bottom frame flange, and call it good. It's not worth the trouble attaching it to the top flange, in my opinion.
As far as rivets vs bolts, it'd be REALLY unhandy to do a clutch job without removing the crossmember. Probably impossible on some transmissions. If there's rivets there, cut them off, and replace with bolts.
Old 12-29-2020, 10:00 AM   #31
ls1nova71
ls1nova71's Avatar
I should have been more specific, the crossmembers are riveted in on manual transmission equipped Chevy and GMC trucks from 67-72. I suspect they stopped doing that in 1973 when the body style changed.
Old 12-29-2020, 10:07 AM   #32
kipps
Makes sense. Thanks for the clarification.
Old 12-29-2020, 10:53 AM   #33
kev2809
low n' slo
kev2809's Avatar
ah ok good info. i didnt even pay attention while i was under there. guess its coming out then
-_--_--_ _________
Old 12-29-2020, 11:14 AM   #34
ls1nova71
ls1nova71's Avatar
Your truck is an automatic, right? If so, you can use the crossmember you have, just slide it back and drill new holes to bolt it back in.
Old 12-29-2020, 04:09 PM   #35
kev2809
low n' slo
kev2809's Avatar
yup it is auto. ill pull it out to paint it. i dont know why i thought these were riveted in
-_--_--_ _________
Old 01-22-2021, 11:20 AM   #36
racecougar
racecougar's Avatar
https://67-72chevytrucks.com/vboard/...&postcount=611
Been running that setup for almost 4 years now, and it has worked very well. Currently installing a Vintage Air system and finally painting the front clip.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
