02-17-2021, 10:00 PM | #26 | |
Re: 3/4 Ton - Front end rebuild vs disc brake conversion
He also builds those little three wheeled beer cart conversions.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 02-17-2021 at 10:10 PM. |
02-17-2021, 10:23 PM | #27 |
60-66 Nut
Sorry but no that is not a '71-'72 C20 suspension. The dust shields, brake hoses and engine mounts are '73+
02-17-2021, 10:59 PM | #28 |
More questions...
I’m thinking I should buy new parts, so can I go to Rock Auto for these? Power Steering gear: I want a quicker ratio, I think the new ones are 3 to 3-1/4 turns? Is there a better place to buy one of these? Will I need to get a bracket to mount the steering gear, like Captain Fabs? Pitman arm: Will I need a special one for a quick turn steering gear, or the stock one is ok? Power steering pump: Some of these don’t have reservoirs, which is best? Anything special about the PS pump and bracket for a 292 inline 6? Hoses - ok to buy from Rock Auto?
1963 C20, small window, long bed 292, 4-speed |
02-17-2021, 11:03 PM | #29 |
Yes, you could unbolt your current front crossmember, roll it out, then roll the new one in. You would need to figure out a way to support the engine though since you'll be taking the lower support of the engine mounts away
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-18-2021, 12:00 AM | #30 | |
I apologize for any confusion. |
02-18-2021, 03:19 PM | #31 | |
02-20-2021, 07:13 PM | #32 |
Can I remove the ball joints with the front cross member on the ground? Is a spring compressor required? Are straps ok to hold the springs?
I’m thinking I should replace the upper and lower control arm bushings too. Is this fairly easy?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 02-20-2021 at 07:21 PM. |
02-20-2021, 07:24 PM | #33 |
You 'can' but it will add complexity for safety w/o the vehicle weight as a factor.
02-20-2021, 07:26 PM | #34 |
So maybe wait till it’s on the truck?
02-20-2021, 07:52 PM | #35 |
It's do-able. Disassembly for sure so you can clean & refurbish as desired. Reassembly (putting the coils back in place) is where it will become a PITA.
