Old 02-09-2021, 04:01 PM   #26
Re: Steering Stabilizer for 2WD
Originally Posted by Wgesnerjr View Post
That's disappointing to hear about the coppers. So far I've liked them. Really wanted BFG Radial T/A's but thought I would save some dough with the coppers. Dang it!
I have always had good luck with Coopers when I bought them. All brands can have ooops once in a while (or more often like Firestone). Never had a crack issue and they always seemed to wear well. I will say though I have switched vehicles after about 20K on those that I had them on, but I didn't change vehicles because of the tires.
Old 02-10-2021, 10:35 PM   #27
russellmarling
russellmarling's Avatar
At my repair shop, we only sell Coopers at customer request now. I've had so many broken belts and noise concerns that it just isn't worth trying to sell them and ending up with an unhappy customer.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 02-11-2021, 03:31 PM   #28
Wgesnerjr
Wgesnerjr's Avatar
Update: put the spare on the truck and went for a ride. Dramatically better. Only slight vibration at 73 mph but if I wasn't looking for, I would have overlooked as a 35 year old vehicle.
I have ordered a new tire and will have it installed Friday. Hopefully this will be the trick to solving this.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 02-12-2021, 04:33 PM   #29
Wgesnerjr
Wgesnerjr's Avatar
Had the new tire put on and took it for a ride on the freeway. No better or worse. Starting to think the Coopers may be out of round. Going to look into Tire Turing or Tire Shaving if I can find out if they are out of round. The future will be BFG Radial T/As but for now, it will have to be.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 02-16-2021, 04:00 PM   #30
68 TT
Still plays with trucks
68 TT's Avatar
With larger tires the normal wear caused minor clearance increase loosening of the wheel bearings will really be pronounced.
Initial assembly under preloading of the wheel bearings during a rebuild can cause this too, especially with new bearings as they need more preload than used bearings.
I suggest checking the condition of the wheel bearings and making sure they have the proper amount of preload on them.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 02-20-2021, 09:08 AM   #31
LT7A
Wg, thank you for documenting your follow-up efforts. I had initially skipped this thread because I wondered why two wheel drive might need a steering stabilizer. But I decided to check it out and am glad I did. If / when I have the front end apart it looks like it would be worth adding the brace. Even though your major problem is probably the tire or tires, it's still is interesting to me how much of a difference the brace made. I plan on running 275s, so not quite as wide as you have, but still probably worth the effort to brace the front end.
Old 01-16-2022, 08:50 PM   #32
Encinoman45
I had installed that Autofab brace in my truck but ended up taking it off again in frustration. It was nowhere close to fitting properly so I had to do the same grinding and modifying to get mine to somewhat fit, and to top it all off, it threw off my alignment somehow.
Encinoman45 is offline   Reply With Quote
Old 01-16-2022, 09:18 PM   #33
kglowacky
I need to look up the brand of brace I installed on my 78. It bolted right up and all the hardware was there. I was convinced to install this as a support so thaty the steering box holes would stay in tack also.
Update. I bought mine from OFFROAD Design. Carrbondale. col.
Part Number. GU9001-2wd 1
It fit perfectly. No grinding. just bolt6 it on.
kglowacky is offline   Reply With Quote
