Old 12-23-2003, 03:14 PM   #26
JimKshortstep4x4
David,
Thanks for the chuckle!
good luck.
Jim
Old 12-23-2003, 03:28 PM   #27
Alex Hayley
Jim, what do you do for your customers(if you use van tilts that is) when it comes to getting a shaft the correct length? Do you collapse the shaft, cut it or buy one the correct length?
Alex Hayley is offline   Reply With Quote
Old 12-23-2003, 04:12 PM   #28
griesel72
griesel72's Avatar
got it, thanks for the help guys. Once again the board prevails.
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-23-2003, 04:12 PM   #29
griesel72
griesel72's Avatar
again
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 05:35 PM   #30
racedvl
racedvl's Avatar
AWESOME!!!!!
racedvl is offline   Reply With Quote
Old 12-23-2003, 06:04 PM   #31
Yukon Jack
Post Whore
Yukon Jack's Avatar
Okay, since I'm doing the same thing shortly, let's idiot proof this - am I correct that I take off the van tilt column's part that is circled and then replace it with the corresponding part off of my old steering column?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-23-2003, 08:24 PM   #32
griesel72
griesel72's Avatar
Yeah, you have to undo the bolt that clamps that thing you circled and replace it with a "shortened" shaft that you got off your old column. (they failed to mention that in the article i read about this swap) I tried hitting it with a hammer, but got no response, so i put it in the press, and it worked good.
it's pretty easy, and if you have your seat out like me, it only took an hour, even with my waiting for help from the board.
Good luck
david
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 09:25 PM   #33
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I drilled the nylon rivets out on my collapseable shaft and it slid down pretty easy when hit with the hammer.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-23-2003, 10:39 PM   #34
JimKshortstep4x4
Talking
Alex,
I am not in the business even though I have done a lot of them.
I don't advocate cutting and welding on front end parts so I have been collapsing the shaft extension as Griesel did. I have run into a Van tilt in a motor home that has the shorter shaft in it. This was an 88 motor home.
When I do a tilt, I install the upper and lower column seals. Here is a pic of the upper part on one that I just finished up for my son.
Jim
Old 01-01-2004, 09:02 AM   #35
wHATANERD
wHATANERD's Avatar
The Van column I installed in my truc also has the cruise control turn signal, don't cut the wires, that about a 100 part in the LMC catalog, I left mine in the column, and salvaged the cruise control equipment out of an 80 Oldsmobile and and put it to work, it is the same switch was was used on 1969 truck equiped with cruise
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 01-30-2004, 10:25 PM   #36
minibike
minibike's Avatar
If you collapse the shaft, you are getting rid of a very important safety feature. I pulled mine apart, shortened it and reassembled, allowing the shaft to collapse in a collision. It was a little more difficult, but may keep it from going through my chest!
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-30-2004, 10:32 PM   #37
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
wHATANERD, the cruise switch you got is not the correct one if you are doing a correct resto. It is the one that you'll get from LMC, but it is not correct.
minibike, when you collapse the column, you are not doing it all the way...only an inch or two. There is still plenty of room for it to collapse.
Old 01-31-2004, 12:22 AM   #38
Glen
If you pull the rag joint off you can convert to a splined U-joint.
Glen is offline   Reply With Quote
Old 01-31-2004, 12:45 AM   #39
Tanker350
Glen
Glen,
I'm doing the same thing you are doing with the u-joints and shaft. What Part #'s did you use and did you use Flamming River? I was gonna use # 1702 and 1703 for the u-joints, but not sure with shaft # to use. Thanks for any help you can give.
Tanker350 is offline   Reply With Quote
Old 01-31-2004, 12:52 AM   #40
Glen
Sorry, I dont remember the part numbers. The joints are flaming river and I buy long pieces of their Double D shafts and cut them to length. Using a 50 cent dowl rod from Home depot is a good idea so you climb back in the cab and check comfort before cutting a steel shaft.
You can also cut the top off of the wifes broom handle, but I reccomend this only if it is late at night and home depot is closed.
Old 01-31-2004, 02:04 AM   #41
wHATANERD
wHATANERD's Avatar
Cruise Control Button
Longhorn Man, I believe the 1969, and 1970 models did use a cruise control button in the turn signal lever, however since this was a dealer installed, and not a factory install option in 1971, and 1972 models the familar cruise master button mounted under the steering coloumn was used since the steering coloumn did not have to be disassembled, and did not void the factory warrenty on the steering coloumn
Old 01-31-2004, 09:28 AM   #42
Longhorn Man
Actually, in 71 and 72 they were assembly line installed, but they were just like the dealer installed units under dash...actually, i think that was for 72 only.
The switch, being described, (which I personally have in one of my trucke w/cruise) is not the correct switch. It is a later switch. You can find this common switch in many GM vehicles up into the early 80's. I should have kept the pic of the correct ont...but this isn't it.
Old 01-31-2004, 01:18 PM   #43
wHATANERD
wHATANERD's Avatar
Evan if it's not the correct switch, it looks good, and is functional, If I was keeping the truck totally original I would be install a van tilt anyways. Thanks for the input
Old 02-01-2004, 02:36 AM   #44
Longhorn Man
Very good over looked point.
I just wanted to make sure you knew, WAY too many ppl see the part in LMC...and if LMC sells it, then it MUST be correct.
