Old 04-27-2021, 03:54 PM   #26
Bbarbeau
Re: Towing 27ft, 5600 lbs Camper with the 71 SWB
I set my C20 up for this 1982, 34’ Airstream. It’s not all that heavy really, about 6500lbs. I'm using the old style Reese Dual Cam and that hitch has worked really well for me.
____________________
72 C20 Highlander, 350
Bbarbeau is offline   Reply With Quote
Old 05-17-2021, 10:23 AM   #27
dz1087
That looks like a nice setup.
dz1087 is offline   Reply With Quote
Old 05-17-2021, 10:25 AM   #28
dz1087
Well fellers, After white-knuckling it back home with a very slight breeze (5kts), I decided I did not have enough gear or wheel base to be towing this thing interstate. Sure, I could re-gear the rear, but that won't fix the SWB.
So, I went and bought a 2015 2500 with the diesel. Yay payments!
Old 05-17-2021, 12:23 PM   #29
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yabut, that rig will drag your trailer right along the road! Good choice.
~Steven
Simi Valley, CA
Old 05-17-2021, 03:47 PM   #30
body bolt
I tow this '68 Silver Streak Sabre with my '71 LWB C10 Custom Deluxe 350/350. It tows fine with the weight distributing hitch but I'd like a bit more stopping power from the truck. This campground is outside of Red River, NM at 8000 feet.
body bolt is offline   Reply With Quote
Old 05-18-2021, 01:50 PM   #31
dz1087
Nice setup. I think I would have been fine towing with a LWB. The SWB and low weight were just not a safe combo for long hauls like we were planning.
Old 05-18-2021, 03:06 PM   #32
body bolt
I suspected the SWB might be a problem when you posted but you never know until you try. A newer truck is much safer.
Old 05-18-2021, 03:44 PM   #33
54blackhornet
54blackhornet's Avatar
I am sure you and the family will be safe in the 2500...Good luck with your vacation...
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-18-2021, 04:14 PM   #34
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Glad you made it home safe. I have a SWB and I wouldn't even try to pull that trailer with it. I have a 2500 Dodge Cummins that is well traveled just for those occasions. I am also building a Dually BB 69 1 ton for a Gooseneck Hitch that will see some fun.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-18-2021, 08:11 PM   #35
dagnabbitt
dagnabbitt's Avatar
Sounds like someone might be looking at a C20 at some point! Good choice on the new truck though, if you are planning on going more than a hundred miles out of your way it is nice to have that peace of mind.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 05-18-2021, 09:39 PM   #36
chevmn
About 25 years ago I had a short bed (92 silverado 350 5 spd manual with 3:73 gears), and purchased a 21 ft. travel trailer. That was the toughest trailer I have ever towed for whatever reason, and the wheelbase of the truck sure did not help. I sold that trailer and bought a 27 ft. fifth wheel trailer and it was a lot easier with that same short bed truck. Easier to hitch, easier to tow (harder to back though). I did a lot of towing with that short wheelbase truck, between travel trailers, and a flat bed car trailer on 400 mile excursions to Indiana, but would not try it again with a short wheelbase truck. I have considered getting either another travel trailer, or small motor home when I retire (in about a year), but leaning toward the small motor home, especially since I only have a 1/2 ton truck, albeit now a extended cab 4x4. Wish I would have sprung for the 2500 with a 6.0 when I bought this truck (in 2011) or they sold a max tow package then with the 6.2, and better gearing. I do have a project truck which is a C20 with big block, but really have no plans to try towing long distances, even though the original owner did a lot of towing with it.
chevmn is offline   Reply With Quote
Old 05-19-2021, 12:01 AM   #37
StingRay
StingRay's Avatar
A vintage big block truck would get about 5 mpg towing a trailer or with a camper on the back. When gas was 50 cents a gallon it wasn't a problem. Even a small block 3/4 ton of the day pulled like a train. Our 4.10 geared 69 Longhorn with a 350 would haul at 65 mph with a 2800 lb camper and pulling a boat through the mountains in 90 degree temps. It only had an in cab tank and we made a lot of fuel stops.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
