#26 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Random No Start?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#27 | |
laying low
![]() Join Date: Mar 2001
Now this makes sense. So it is more an issue with secondary wire gauge from ignition switch to starter solenoid experiencing voltage drop due to under hood heat rather than positive battery cable voltage drop from battery to GM starter solenoid. This is what lost me. I knew power from the ford solenoid still had to go through the GM solenoid to engage the starter drive. Thank you.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#28 |
There are believers in the idea that hundreds of millions of GM vehicles used the same starters and wiring and they worked, which they did, and there are those who don't.
Fix the underlying issue and the solenoid will work. Typically, the underlying issue is bad wiring and/or poor connections, or worn out (resistive) switches in the circuit. Of course, a bandaid solution is easier than troubleshooting so it's popular. Yes, it's a bit of a long path from the battery to the solenoid, but I've jumped solenoids with a 20G or smaller jumper, so it doesn't draw that much. Measure voltage to the block and to the battery from the S-terminal. Last edited by franken; 05-16-2021 at 12:18 AM. |
#29 |
Just dealt with a similar issue on my Dad's '70. His truck's issue was a wiring problem.
Turned out to be the ignition wire between the ignition and the coil. A wire loom mounted near the top of the firewall carries it across the engine bay. The wire had broke in two inside the wire loom. The problem did not recur after splicing the wire back together. |
