05-22-2021, 08:12 PM | #26 | |
The Older Generation
Re: Dana 60 3.54 in the '68 Chevy C20
The shoe with the lining farthest from the top would go on the front. LockDoc
05-23-2021, 03:45 AM | #27 |
I agree, the bare lining table at the top should be forward..
interesting that the lower end of the rear shoe lining table is also bare.. probably cost savings, only manufacture one lining, just oriented for F or R shoe..
I started out with nothing - and I still have most of it |
05-23-2021, 04:02 AM | #28 |
good job on that axle swap Doc!
I scored a D60 4:10 LS leaf sprung for my k20 burb, then later scored a 4:10 locker third for the 4:10 eaton in it.. red longhorn has a factory locker so thinkin I might haul that D60 home for the ochre longhorn.. swap my leftover 4:10 eaton gears into the red longhorn and everything will be just right for my uses
05-23-2021, 04:56 AM | #29 |
I bought the same NAPA shoes a couple of years ago and found the same problem. At the time, i checked the other retail part stores and found the same shoes. They all had part numbers that were a variation of Napa's 419 part number.
This thread from last year talks about the same shoes. https://67-72chevytrucks.com/vboard/...ighlight=shoes The shoes seem to work OK when driving. Having disc brakes on the front may be a factor on that. I did find that when parked, nose up on a hill the e-brake had to be applied extra hard to keep it from rolling back. You don't always have curb to turn the wheel against. I think it sucks that they can't give you the correct lining length for the rear shoe.
'67 GMC 2500, 292, 4spd, AC |
05-23-2021, 03:43 PM | #30 | |
Thanks. That sounds like a lot of swappin' to me. I was glad to get the one done.... I needed the 3.54 to make it easier to drive on the highway. I do very little work with it. Heck, I do very little work anyway... LockDoc
05-23-2021, 05:36 PM | #31 |
I did a coil spring Dana 60 swap last year for a friend. What did you do for the track bar? I think that the bracket at the frame is different. Stock track bar from the Eaton was a different length and the angle at the bracket on the frame was more than the one for the Eaton. I shortened his and am looking for the correct bracket. When I got the rear end, I got the rear part of the driveshaft and the track bar but didn’t think to get the bracket. Glad to see someone else has done this also. My friend really likes the 3:54 versus the mid 4: ratio that the Eaton had. I think you’ll like it too.
05-23-2021, 05:49 PM | #32 |
That may be more a function of cable slack than shoe surface length. Agree, I wish they still manufactured correct length linings too. I bought some shoes for a 71 D60 4.10 about 10 years ago and they were correct, or at least as best I can recall - the rear shoe was indeed much longer than the front shoe.
05-23-2021, 08:11 PM | #33 | |
I heated the Dana 60 bar right in the middle and bent it over so it lined up with the frame bracket, jacked the frame over about 3/8 inch toward the passengers side and put the bolt in. Lined up on the first try and the bolt slid right in. LockDoc
05-23-2021, 08:22 PM | #34 | |
http://67-72chevytrucks.com/vboard/s...ght=Brake+shoe
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
05-16-2023, 09:34 PM | #35 | |
Active Member
The reason I ask about the donor, is that I do not know if there is a difference in the brake package between a C20 Suburban Dana 60, a C20 Truck coil-sprung D60, and a C20 leaf-sprung D60. It sounds like your new rear has the 12x2.5" brakes that G70 trucks have.
1971 Pontiac Firebird 1971 GMC C2500 |
05-16-2023, 10:27 PM | #36 | |
Not 100% sure. I think I picked it up over at the salvage yard. They are kind of hard to find. LockDoc
05-17-2023, 12:45 AM | #37 |
If you are looking for a Dana 60 you might look under the Dodge trucks. My GMC 2500 came with the 292 six and a Dana 60 with 4.56 gears. I ran across a Dodge D200 with 3.54 gears and a posi carrier in a wrecking yard for $50. The Dodge Dana is the same except for different yoke splines and they use the smaller "U" joints. A 4 wheel shop had a yoke with dodge splines, but for the larger "U" joint.
3.54 gears, even with a six, made a bigger, single difference than most everything else I have done to the truck, except maybe the AC.
05-17-2023, 10:47 PM | #38 |
Active Member
I talked with a guy from VintageChevyTrucks and he did say that C20s with coils are uncommon and that C20 suburbans would be the best bet.
I currently have a Dana with 4.10s and, yes, even with my 4L80 I'm going to switch to 3.54s. Maybe I'll make a post in the suburban section and see if anyone knows if their Dana has 12x2.5" brakes.
1971 Pontiac Firebird 1971 GMC C2500 Last edited by sloGMC; 05-17-2023 at 10:55 PM. |
05-18-2023, 11:54 AM | #39 | |
05-18-2023, 12:15 PM | #40 |
At the body shop.
Dad said the 3.54 gear would swell the converter up to the point of killing the thrust surface in the 454 in old blue.
True ? I don't know. But probably pulling this up the grapevine at 55 in 2nd had more to do with it.
" That didnt make it any newer " " Dont antique the equipment " |
05-19-2023, 11:05 AM | #41 |
Active Member
Sort of. My truck came with a 400 and the optional 4.10 gear set. What I can't make sense of is why GM didn't offer the coil sprung 4.10 Dana with a 400. My guess would be that the trailing arm suspension would handle the torque even better than a leaf set up but, other than reducing the amount of rear end variations available I can't figure why it wasn't offered.
06-06-2023, 12:41 AM | #42 |
Most Canadian trucks had coil springs, Chev or GMC. At least that has been my experience.
09-14-2024, 11:29 AM | #43 |
subscribed
09-14-2024, 07:46 PM | #44 |
I sold the truck shortly after the swap but I'm kind of sorry I did. It was really fun to drive with the new gears.....
09-14-2024, 09:47 PM | #45 |
3.54's made a world of difference in my '67. I put an Eaton Tru-Trac in it at the same time, couldn't be happier with it.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
