05-23-2021, 04:36 PM | #26 | |
Re: Three questions 87 TBI ....
05-23-2021, 05:23 PM | #27 | |
If I remember right, there are only 3 tbi springs, gold 12-15psi, brown 17-18psi, and the 94-95 454 spring (silver? Maybe) again going off the top of my head here. The 94-95 454 injectors also changed to a smaller size, and higher pressure for better fuel atomization, if I remember right. And the ep381 CAN provide up to 60 psi of working pressure (they deadhead at around 100psi) but again pressure is set by the regulator, not volume Edit: also, something I think that may be helping using the “higher pressure” pump is that if the ep386 produces 15 psi, that’s 15 psi with 12 volts. Over the years, corrosion etc, your pump may only be getting say 10 volts, which would only put enough volume out to produce say 11-12psi (just throwing numbers out) where the ep381 will still provide enough volume to produce 15 psi with reduced voltage. Hopefully this doesn’t complicate the thread Last edited by 44th Miss Inf; 05-23-2021 at 06:00 PM. Reason: Added thoughts |
05-24-2021, 08:07 AM | #28 | |
05-24-2021, 12:23 PM | #29 | |
OBTW, I ordered the EP377. I figured it is better than stock, and hopefully all my little 305 needs .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
