04-05-2022, 07:00 PM | #26 |
Re: Good Wood
Nice looking deck. I'd be afraid to haul anything messy in the bed, after that.
On the other hand, I might use real director chairs at a tailgate BBQ, rather than the nylon pop up chairs I use now.
04-06-2022, 06:21 AM | #27 |
Re: Good Wood
Looking good!
71 C10 72 K20 72 K10 Super Kirk |
04-06-2022, 08:02 AM | #28 |
Re: Good Wood
Nice work!
04-07-2022, 04:31 PM | #29 | |
Re: Good Wood
If you can deal with industrial strength , it will cut down on the process time and it will give you the aged penetration through the entire depth of the wood , Again this is done outside I can not stress this enough and I would add use appropriate PPE when doing this . So if you want a real deal aged wood look nothing else comes close. |
04-12-2022, 01:17 PM | #30 |
Re: Good Wood
I painted my bed wood to match the truck color. I began with red oak because I got it cheap. I have never heard of doing what i have done but I started out by saturating the wood with epoxy sealer (Smith's CPES), then smoothing the pores of the wood by using Total Boat Total Fair (A boat fairing epoxy used on wood boats sold by Jamestown Distributors. I have spend years working on wood boats and can guarantee this finish is bullet-proof from any sort of weather. Most folks cannot believe it is wood. But even if you want to just varnish your wood coat is first with epoxy sealer. I have quite a few more tricks regarding this process if anyone wants to learn.
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
04-13-2022, 12:47 AM | #31 | |
Re: Good Wood
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
04-13-2022, 08:32 AM | #32 |
Re: Good Wood
I cannot! That is a problem. But it is the same question I would ask of everyone who varnishes their wood. Just for looks. Makes it a bit of a worthless truck.
04-13-2022, 10:49 AM | #33 |
Re: Good Wood
Georgie, would West 105 make a good first coat?
04-13-2022, 07:24 PM | #34 |
Re: Good Wood
Thanks for asking. Years ago I used West system products but after awhile i just found them too expensive and not any better than other companies where I buy epoxy resin and hardener in bulk and also buy the fillers way cheaper in bulk. But the problem with West is that they do not really have a thin epoxy sealer that will soak into the wood and harden it in order to create a good substrate for subsequent layers of whatever epoxy you want to put on top. And after awhile I have become tired of mixing epoxy and creating my own "epoxy bondo" using epoxy and various fillers, always trying to achieve a good balance between flexibility and sandability. In general hard epoxies do not sand well. That is why I like the Total Boat system of epoxies form Jamestown Distributors. Their Total Boat fairing compound mixes equal parts of blue and green pre-thickened epoxy that is already formulated to sand easily and be somewhat flexible. No guesswork and no serious measuring. After I get my wood "fair" (smooth and level) I coat with an epoxy barrier coat from other companies. This barrier coat acts as an epoxy primer and since it is guaranteed waterproof to use on wood and fiberglass boat bottoms it will effectively seal water from any truck beds that you want to paint. Of course you need to treat the edges and bottoms of all boards equally or water will get in. But wood CAN be made impervious to moisture. Most of what I read on this forum is suing old technology and not even prepping the wood correctly. For instance paint sticks better when you round the very sharp edges by hand with a simple block and sandpaper. Finish failure always begins at these sharp corners. So eliminate them.
04-13-2022, 08:12 PM | #35 |
Re: Good Wood
Wow thanks for the response Georgie. I bought the West 105 with the 207 Special Clear Hardener. Mainly because they say "Blush-free 207 Special Clear Hardener was developed for coating and fiberglass cloth application where an exceptionally clear, moisture-resistant, natural wood finish is desired."
I plan on staining my wood and then coating with the 105/207, then I planned to use regular automotive clearcoat over that. Probably SPI Universal Clear. Can't remember how I came up with this plan since it has been about 8 months since I bought the West 105/207 Do you think that sounds like a good plan? I did put a pretty good radius on all the edges when I was sanding the white oak. |
04-13-2022, 08:28 PM | #36 | |
Re: Good Wood
Epoxy applied straight to wood just sits up on it too well and does not penetrate. Hard epoxy can crack and lead to failure. A softer epoxy avoids this potential for cracking. Stains under epoxy are sometimes tricky if you do not let the stain completely dry. Just make sure yours is dry or hte epoxy can "muddy" it. I would be most interested in your experience with automotive clear coat. In general epoxy hates sunlight and should be protected by the best UV resistant barrier you can find. I would consider first applying a few layers of some of the highest rated UV protecting varnish you can find before applying the clear coat, unless the clearcoat states it has UV protection in it. That is something I have no experience with. The sunlight really tears up epoxy making it brittle and fragile and literally falling aprt into dust if not protected properly. But an epoxy layer under any varnish will also help fill in the pores of the wood and so many of these wood beds I see with "12 coats of varnish" still have not filled in the wood pores effectively and those pores can admit moisture eventually. And too many folks make the mistake of suing polyurethane. That is the worst! Good luck and let me know how the automotive clear coat works out. If it was me I would be researching some of the high-tech spray-on clear coatings developed for the marine world,
04-14-2022, 08:36 AM | #37 | |
Re: Good Wood
04-18-2022, 05:49 PM | #38 |
Active Member
Re: Good Wood
Georgie that bed looks amazing..Nice work..But mine will stay a working truck patina and all..Lol
I have the bed mostly done..just need to snug up all the nuts and then add a touch of silicon on them to keep them from coming loose... Does any one know where I can find factory style exhaust hanger brackets. the part bolted to the frame rails that the hangers are mounted to..I am installing a dual exhaust system. Last edited by YellowK5; 04-18-2022 at 06:09 PM. |
06-18-2022, 01:37 PM | #39 |
Re: Good Wood
Any updates on this, auto clear over epoxy....georgie if I coated Ash with Total boat epoxy, 1/2 gallon thinned down maybe 1 good wet coat rewetting before it drys..both sides and auto clear over..3 days or so later ...this would be fleetside long bed. Not a show truck, parked inside. And sanding before epoxy, 320 grit?...what about recoating a thicker clear epoxy as top coat instead of auto clear?...Thanks....the paint to match wood floor looks amazing, but I do want to use the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
06-19-2022, 09:02 AM | #40 | |
Re: Good Wood
You are on the right track. To start with I would not sand the wood past 120. If you want to sand with 320 do that just before you put your topcoat on. But if you do what you are doing it should work out well. The key thing you are doing is thinning the first coat and getting a couple coats on both sides of the board (and edges, and ends). I would still sand with 120 after the first coat of epoxy. Another key thing to keep in mind with epoxy is that sunlights degrades it. It will not hold up in the sun unless there are UV inhibitors on the topcoat. Most of my work is with wood boats so I simply use a varnish that clearly states it has a lot of UV inhibitors in it. I do not know if auto clear coat has any UV inhibitors in it. Painting with a solid color topcoat will solve all your epoxy problems. And here is another TIP: acrylic latex primers work better over epoxy than any oil-based products. The oil will work but it just takes a long time to dry over epoxy. You could just do a nice job with a brush and it would probably look fine (especially if you know how to work with a brush). All the work I did on the boards in my truck bed was with a brush. The topcoat was the only coat that was sprayed. Good luck with it and keep in touch. We love photos.
06-19-2022, 09:48 AM | #41 |
Re: Good Wood
Thanks for the follow up, I need to find some parts before I dive in to deep, truck has a steel floor and I would like to add aluminum cross pieces and the bed wood. Not opposed to painting the boards like you did, and using stainless strips. 120 grit sounds too easy, I like that.
06-19-2022, 09:56 AM | #42 | |
Re: Good Wood
07-22-2022, 07:28 PM | #43 |
Re: Good Wood
Just about done with my upper deck project, materials and program completely different from original plan....Stainless strips were backordered or too expensive, I decided to use what I have.3/4" cypress with pvc raised strips. Cypress milled and sanded, 1 coat of epoxy primer brushed on, 1 coat sprayed on. Base coat and clear spayed on the top. 1" pvc board, 4 dabs of polyurethane caulk hold each cross piece in place, nutserts used to attached the strips..with Stainless truss head bolts....Square Stainless tube at the rear covers the ends.
07-22-2022, 09:55 PM | #44 | |
Re: Good Wood
07-22-2022, 10:46 PM | #45 | |
Re: Good Wood
07-23-2022, 07:24 PM | #46 |
Re: Good Wood
We use kiln dried Northern Red Oak for our trucks. It is super durable and stains really well.
This bed is Red Oak with Minwax penetrating oil, 3 coats of Dark Walnut Marine Spar Varnish (sanded between each coat) then a coat of Polyurethane Clear. Lot of work, but well worth it. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
07-25-2022, 12:34 PM | #47 |
Active Member
Re: Good Wood
Nice work Pops! I also used red oak but no stain..I am happy with how it looks..If it looked like yours I couldn't use the truck as a truck...
Scott |
