Old 10-07-2021, 06:37 AM   #26
biketopia
Re: For anyone looking to Go with Holley Sniper EFI
IF you're on a facebook there a few good sniper pages too. Don't be scared when you see "everyone" has questions and concerns or issues. They are tech and help pages, so that's the type of questions that get asked. Good info on tuning, set up, etc, Holley is an active member of at least of them too. EFI systems pro site has some good write ups as well.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-07-2021, 02:59 PM   #27
biketopia
You will also most likely need a throttle cable bracket, either lokar or FAST both make one that fits well.
Old 10-07-2021, 04:12 PM   #28
70STOVEBOLT
70STOVEBOLT's Avatar
Will the EFI unit bolt onto a spreadbore intake without an adapter? Holley recommends a sealing plate.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-07-2021, 04:22 PM   #29
jimijam00
The Snipers are dual pattern, so it will go on without an adapter/spacer, though you should make sure the blades aren't hitting your intake, which would then need a spacer for sure.
The sealing plate recommendation comes after some complained of a whistling sound. Some like the whisle. Some have such loud beasts under the hood, they cannot hear the whistle.
jimijam00 is offline   Reply With Quote
Old 10-07-2021, 04:27 PM   #30
70STOVEBOLT
Ah, ok.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-07-2021, 04:32 PM   #31
jimijam00
This will do the trick and help keep heat away from that little computer in the TB. As I see it, keeping heat away from the computer can only be a good thing.
