#26 |
All about them K’s
![]() Join Date: Jun 2014
Re: Rust on ring and pinion
You will need a 10.5” to be comparable in strength to the HO52 as well as being bolt in. A square body K30 1 ton (77-87(91) will have the correct 40.5” axle perch spacing and be a 10.5” full floater. You will only have to cut and re-weld one shock mount for it to be bolt in. You will need to re gear your front axle to 3:73 If changing ratios. 3:73 should be fine with a th350 if on stockish size tires. If you are lifted and on 33-35’s I’d suggest 4:11.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#27 |
![]() Join Date: Aug 2019
Something else to think about. What does the inside front differential look like? Is it as rusty as the rear? Is there any rust in the axle housing? I would derust everything, buy any new parts I could find, polish the ring and pinion and put it back together. The longer you drive it, the less you will even remember that there was rust in there.
#28 | |
Post Whore
![]() Join Date: Feb 2016
So your truck is a 4x4? K20 or K30? We'd love to see some pictures. And 3.73's would be fine with the TH350. Just be aware the front carrier will only work with 3.73 and numerically larger gears. The link has more information. https://www.drivetrainamerica.com/bl...als-explained/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#29 | |
![]() Join Date: Jun 2021
According to your link I can't put 3.73 in a 4.10 differential ? What it looked like when I picked it up ![]() ![]() What it looks like now ![]() Last edited by Johnl48; 10-04-2021 at 07:16 AM. |
#30 |
That whole carrier, ring, pinion, and all bearings are trash. Period.
Could it function for a while? Maybe. Define "a while." I would 100% not reuse any of that. |
#31 | |
Post Whore
I wanted to point out there are limitations to ring and pinion swaps if changing the carrier is not an option. That information may limit your rear axle choices.
#32 |
I agree. It appears to me there's more than rust going there. Those gears actually look pitted to me. I guess if you're willing to deal with a complete grenade at some point, it would be a fun experiment to see how long it would last if you put it back together and run it. Don't know if you have the extra time for that or not. New is the only way to deal with it one time.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
#33 |
3.73 don’t exist for the HO axle which is why you can’t swap them in. Don’t forget that front has to match rear with gear ratio.
#34 |
Its a Truck Thing......
John,
I have a Eaton Dually axle that I am about to scrap. I wonder if anything off it could help you out. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#35 |
Post Whore
Your truck's progress is looking good. Keep us posted.
#36 |
#37 | |
Smitty
#38 |
Would these work ??
#39 |
All about them K’s
The front will bolt up. The rear will need the perches and shock mounts moved. The rear has to come from a 1 ton 4x4 to be basically bolt in minus 1 shock mount.
#40 |
Carpe manana
![]() ![]() Join Date: Dec 2010
It's a myth these parts aren't available. In the last year I've been able to source all manner of gaskets, bearings, studs (71-72), drums, etc. as spares for the Eaton HO52 in my 72 K20. These parts can still be had. Rebuild it and it will last another lifetime.
Here's a good start: https://torqueking.com/category/1967...052-rear-axle/
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 10-04-2021 at 08:43 AM. Reason: added |
#41 | |
#42 |
Should have the dually split tomorrow.
Smitty
#43 |
Those 3/4 ton axles would work. They are not from a military truck though… the Blazers were 6 lug and the trucks were Dana 60/FF 14 bolt. Those are most likely from a Suburban which makes a fine donor for an earlier truck. Big improvement in brakes but the 9.5” 14 bolt not as strong as the HO52. But it doesn’t sound like you need the strength.
FWIW, if those axles were close to me I’d own them for that price.
#44 | |
#45 |
Carpe manana
There’s a member here listing a rear 4.56 axle now.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#46 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have an HO52/72 4:56 I'd let go for $200...Has the drums intact. SRW axle...PM me if you want it. FWIW, I'd clean up what you got, replace the bearings and run it! Unless your planning on high mileage with heavy loads that gear set will outlive you! "jus sayin"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#47 | |
#48 |
![]() Join Date: Mar 2021
Good luck
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual Last edited by Jiggers72-GMC; 10-07-2021 at 08:55 AM. |
#49 |
You guys saying to clean up that gear set are either blind or maybe just crazy. Maybe both? The pitting on both of them is very bad. We aren't talking a light dusting of surface rust here.
#50 |
Dually got split, has 4.57 ratio 32ring/7pinion on it. Ring and Pinion actually look good, few ring teeth with pitting but, nothing like yours.
I do have another axle, but it will be a while before I take it out from the motorhome if you are not in a hurry. If you want anything from it let me know. Smitty
