#26 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Some 70s have the wider rear, some don't! Now how would you feel if the guy bought some expensive axles based on your post and they didn't fit?
#27 |
Thanks Injected, Tx and Dinnut.
Is there any way to determine the rear that I have? Looks like I'm going to go do some web huntin' Add another project to the list.
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
#28 |
JadeEmeror, You can determine what rear you have by measuring between backing plates. Here's the link you want: http://67-72chevytrucks.com/vboard/s...threadid=79939
I already did the "research". To paraphrase; short rear - 55-1/2", wide rear - 56-3/4". You can measure that without taking anything apart.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
#29 |
I wish I could post some more pics of the progress but I don't get the camera back until the 31st.
Here's what I've done so far: installed front spindles and wheels and checked for clearance issues. installed the ECE 2" drop springs to bring the truck back up a little. Installed the booster and master(Looks awesome). Installed the rear axles. Installed the rear caliper brackets, calipers, and wheels. I've had it on the ground and I'm happy with the look. Now I'm taking everything back apart to paint(front suspension mostly). I also have to bend a whole bunch of new brake lines. I'm close, oh so close. Time to get dirty.....again.
#30 |
injected, looks like you're right where i was about a month ago. it's amazing how much all that work improves how a truck looks and drives. please post LOTS of pics when you're done. i've been lazy and need to get some pics of mine posted after the 17s, 2/4 drop, and 4whl discs.
could you post or PM me the part numbers you used for the baer front brakes? thanks
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
#31 |
I would like to see some pictures rin68.
Here are some Baer numbers: Front system is the GT+ 63-70 C-10 w/5x5" BC (1301121) Rear system is the TOURING+ 10-12 bolt BIH 5x5" BC (1302095) The front you can order on their own standard spindle or drop spindle. The rear is a universal 12 bolt setup.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album Last edited by Injected68LS1; 12-29-2003 at 03:30 AM. |
#32 |
i didnt know some 70s had the wide some didnt. sorry. now i do...
70 longbed 496/th400/Ford 9" |
#33 |
Cowboy Fan for Life!!!!!!
Don't sweat it dinnut. Thats the great thing about this board. If you spend any amount of time on it, you have no choice but to learn stuff like that. I found out the hard way after someone said, "you can just swap the axles out of a 71/2 into a '70". I bought a .373 posi out of a '70 and went to switch the axles and learned real fast that they all aren't the same. Didn't mean to jump the thread, injected. Nice setup, sweet wheels........Later.......JB
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
#34 |
So I've got the whole front suspension apart at the moment. I just finished brushing POR15 semi-gloss on the a-arms. I'm going to let it dry over night and start installing all of the new components tomorrow. I will also start bending all my new brake line. I even got a stainless-braided line from the frame to the differential. Can't wait to see how well all of that turns out.
Next I will take my axles back out and replace the bearings and seals. Then I'll final assemble the rear brakes and fill up the diff. After that I'll be real close. Bleed brakes and drop it on the ground. I should be done tomorrow night. I hope. Wish me luck.
#35 |
good luck. por15 is very popular stuff! you are bending your own lines? thats cool... you have that kinda machinery in ur shop or where u work? thats cool. are you using moog stuff or what are you using on the front?
#36 |
I finished up with the POR15. It took a while to prep everything. I completely cleaned and painted my crossmember too. I also painted all of the new MOOG stuff - control arm shafts, tie rods. I'm using MOOG ball joints too.
As for bending the lines, it's easily done with a $50 tube bender. That's what I'm starting on in the morning.
#37 |
Good news. I'm almost done. Here's whats left:
Replace rear axles bearings and seals. Bend rear brake lines. Add rear-end fluid. Bleed brakes. Finish alignment. Fix whatever goes wrong. Test drive. I'll post some more pics later on.
#38 |
Another
#39 |
From the rear.
#40 |
wow it looks frickin awesome now dude! what are you using for backup lights? that hood makes it look good? itll look even better when you paint it
![]() wow thatis a sweet truck!
#41 |
sweet, VERY nice ride. that should turn some heads in traffic
#42 |
97' Tahoe 2dr/2wd
good looking california cruiser....
so how much drop did you end up with? |
#43 |
Thanks for the response. I ended up with 4-1/2" in front and i still have the same springs in the rear. I think they are 6". I wanted to go lower in the front but the outside of the tire would hit the fender well.
#44 |
Just Don't Stop!
![]() Join Date: Feb 2004
What are the tire profiles you are running? Looks PERFECT!!!
Thanks! |
#45 |
The LuvShack Garage
VERY NICE, I LIKE YOUR TRUCK.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#46 |
![]() Join Date: Aug 2001
Sweet truck - looks great. Nice shop also!
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
#47 | |
#48 |
Vortec in the works
Injected, your truck is awsome looking,very nice, I like some info on your grill and front roll pan. the shaved back up lights are nice touch.
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. Last edited by TEXAS 68; 02-05-2004 at 11:33 AM. |
#49 |
Flake Daddy
man that looks cool!...i dig that whole set up....and I second Smooth68..nice shop!
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension 1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension 1998 Range Rover 1960 El Camino....in the works..... |
#50 |
Hot Rods For Life
Sweet truck!! (Right click - save.)
