Old 11-16-2021, 08:03 PM   #26
slammed57
Re: Someone else's truck. '48 Chev
looks like its goin to be a killer truck, I'll be following bud
slammed57 is offline   Reply With Quote
Old 11-18-2021, 02:36 AM   #27
lower50's
lower50's's Avatar
Thank you sir
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-01-2021, 08:10 AM   #28
lower50's
lower50's's Avatar
Well been getting a few little things done, mainly waiting on parts. I have ordered as much as I can as soon as I figured out what I wanted but still slow to arrive. But I did get the gas tank ready, it's a s10 blazer tank I'm putting in the rear. Because the motor is carburetor I got a carb sending unit, turns out to be perfect length but too small for the hole. So I made a ring and welded it to the sending unit to give me what I needed and done.
1951 MG TD
Old 12-01-2021, 08:59 AM   #29
8man
Nice solution and good work on that ring.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 12-01-2021, 09:00 AM   #30
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on this one! You're moving right along!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-01-2021, 10:54 AM   #31
oldman3
oldman3's Avatar
Robert, clever ideal...Jim
oldman3 is offline   Reply With Quote
Old 12-02-2021, 08:20 AM   #32
lower50's
lower50's's Avatar
Thanks putting my master hole saw skills to work LOL. A lathe would be nice.
Thank you
It was less work and cheaper than modifying an stock sender.
1951 MG TD
Old 12-03-2021, 07:57 PM   #33
51chevytruck
That seat looks nice! Can you please tell me how wide it is, year?
Thank you,
Tom
51chevytruck is offline   Reply With Quote
Old 12-03-2021, 08:23 PM   #34
51chevytruck
Thank you,
Tom
Old 12-10-2021, 12:51 AM   #35
lower50's
lower50's's Avatar
Thank you,
Tom
It's from the rear of a 2000 Avalanche and measures 57" wide.
1951 MG TD
Old 12-14-2021, 07:34 PM   #36
lower50's
lower50's's Avatar
I got the rear axle all cleaned up, painted with all new brakes and for the first time in years this truck has an axle bolted under it.
Front brake lines are all installed as well as the ps lines.
I got the rad support modified to hold the rad, oh and if you let a motor sit out in the farm land make sure you check the thermostat housing for corn. lol
1951 MG TD
Old 12-14-2021, 09:40 PM   #37
oldman3
oldman3's Avatar
First time I've ever seen that, but I lived in the city for years...Jim
Old 12-15-2021, 09:08 AM   #38
8man
Ha, yep they will store any place that is dry. Oh wait, there used to be water there....
8man-aka Robert
Old 12-15-2021, 09:12 AM   #39
6DoF
6DoF's Avatar
good luck with that!
the I6 that came out of my 3800 had YEARS of mice living in the intake manifold. little jerks used the cylinders with open valves as their nut shell scrap trash bin. there motor was literally "nut locked" and couldn't turn over.
6DoF is offline   Reply With Quote
Old 12-15-2021, 12:43 PM   #40
youngrodder
youngrodder's Avatar
Look on the bright side, with a stat in place it kept the engine from being filled with corn. Otherwise you would have popcorn shooting out your tailpipe.. ha ha
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-15-2021, 06:28 PM   #41
lower50's
lower50's's Avatar
It was siting in a newer garage, really shows they can get in anywhere.
Yes they will, this motor has never had liquid in it yet
Ha thats kind of funny.
ys it did, But that might be fun.
1951 MG TD
Old 12-22-2021, 02:44 PM   #42
lower50's
lower50's's Avatar
The ac/heater came in less than a week from the US I got some rad hoses to work, they are from a 1987 chevy 1500 just had to shorten them a bit. Then I pulled off the bed that was just sitting there and made the gas tank have a home. I'm using 2"X1/4" flat bar for the under tank support then there will be thinner bolt on straps for top.
1951 MG TD
Old 12-22-2021, 02:59 PM   #43
vintovka
vintovka's Avatar
Nice work!!
vintovka is offline   Reply With Quote
Old 12-23-2021, 12:36 AM   #44
oldman3
oldman3's Avatar
Looking good Bob...Jim
Old 01-07-2022, 06:41 PM   #45
lower50's
lower50's's Avatar
Originally Posted by vintovka View Post
Nice work!!
1951 MG TD
Old 01-07-2022, 06:53 PM   #46
lower50's
lower50's's Avatar
Finally got the flywheel and clutch then picked up a starter, to see if everything plays nice together I had to prime the oil system, since it was dry. Then I cranked over the motor everything is good so far. Once the cab was set back on I got the E-brake handle figured out and hooked up. Didn't even adjust the new back brakes and it works.
1951 MG TD
Old 01-07-2022, 06:59 PM   #47
lower50's
lower50's's Avatar
Gas tank hold down straps are made and installed.
Don't you just hate forgetting the flair nut
Shock mounts are made, shocks installed. Gas line and brake lines are all run and secure. Frame is painted, Making lots of progress.
1951 MG TD
Old 01-07-2022, 07:15 PM   #48
lower50's
lower50's's Avatar
The 2.5" stainless exhaust pipes showed up, and apparently there was still something really interesting in the box, it was some packing paper LOL.
Today the clutch peddle assembly showed up, looks really nice.
1951 MG TD
Old 01-07-2022, 08:16 PM   #49
Dieselwrencher
Very nice work! I've bit myself on the tube nut before too.
Ryan
Old 01-08-2022, 12:46 AM   #50
oldman3
oldman3's Avatar
Nice...Jim
