#26 | |
The Older Generation
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
![]() You will get your answer tonight or tomorrow morning..... ![]() LockDoc
#27 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
ok, I'll keep myself entertained for now....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#28 | |
#29 |
Finished spraying the frame today. I have some touch-up to do on it but it came out pretty good. Now to get the engine and transmission set down in it. LockDoc
#30 |
Can't wait to see where it goes, Leon. Hope you and Pat are well.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#31 |
My question has been answered...
. Looking good!
#32 |
BlahBlahBlah
My guess is you didn’t want the stiffness of a one ton in back, but could you have swapped in one ton hangers and springs using the 3/4 ton mounting holes?
#33 | ||
Yup, 8ft bed C30 dually.... Thanks Dale.Quote:
LockDoc
#34 |
BlahBlahBlah
So you would have had to space out the one ton stuff, interesting.
I had no idea they made trailing arms and coils in one tons.
#35 | |
No, the one ton C&C spring hanger brackets need to be made narrower, or new ones need to be made like I did for the rear. I narrowed those up by about 2 inches. Also, they didn't have trailing arms and coils in any one tons. I was going to convert it to trailing arms and coils. I would have had to add a trailing arm cross member, C20 trailing arms, and weld coil spring pads on the rear end housing. The 1 ton coils I have I removed from the rear of a Chevy ambulance that had the heavy duty coils. Sorry about the confusion.... LockDoc
#36 |
Installed the 2003 Chevy engine and transmission this morning. It was originally a 4x4 so I had to source a 2WD transmission for it. I had an ad on CL to buy just the rear tail housing and yoke so I could switch it over. A guy called me and said he had a complete 2WD transmission that he would sell me about as cheap as I could buy the parts and switch mine over..... $500.00. Needless to say, I went and picked it up. I had to make a rear transmission mount because the 2003 mount was too tall. I used a stock TH350 transmission cross member for the rear trans mount. If I had dropped the center of the cross member I could have used the stock Allison rear mount but I think that would have made the engine angle too severe. This is why I installed the '72 big block frame brackets and mounts. (Now 68Gold/white has his answer too.) .. ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-14-2023 at 10:29 PM. |
#37 |
That's a beefy looking powertrain!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#38 |
Yup, Work truck.... .. Chevy 8.1 496ci with an Allison 1000 5 speed overdrive transmission.LockDoc
#39 |
![]() ![]() Join Date: Jul 2002
Sounds like a great combo!
#40 |
nice project
#41 |
Thanks guys. I am looking forward to driving it for sure. LockDoc
#42 |
Set the cab back on the frame today. I had to cut the low hump out and install a high hump. I have about an inch clearance from the transmission to the hump with the new body mounts. I am ready to set the bed back on but I need to do some cleanup, priming, and painting on the back of the cab and front of the bed before I do, and it's raining today. Bummer! I will also need to widen the in bed wheel tubs but I want to see exactly how much I am going to need first. EDIT: I can't believe I forgot to take a picture of the actual cab sitting on the frame. I thought I took one but it isn't on my camera card so not sure what happened. Oh well, you can see it when I get the bed on..... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-27-2022 at 11:47 PM. Reason: Add text |
#43 |
You're moving right along, great progress...
#44 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work Leon! Are the bell housing bolts pretty tight at the firewall. It looks like it might be real fun to swap a trans in? Probably still better than the newer trucks though.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#45 |
Leon, Are those rear tires, Keepers???
They look like you are planning to attach a plow to the trailer ball, and turn some ground...LOL!!! |
#46 |
Subscribed. Real work truck.
'71 C/20 350/T350. |
#47 | ||
Thanks Dale. Quote:
.... They will all be new when I get ready to start driving it.....Thanks. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-30-2022 at 11:44 AM. |
#48 |
My pictures came up missing when I set the cab back on (or I forgot to take any) So here is the cab AND the bed back on the frame.... I won't have to widen the rear wheel tubs all that much. I will do that in the next couple of days. Everything fit really well. Progress! EDIT: I removed the cheapie hitch after I took these pictures. LockDoc
#49 |
That looks awesome. What is the rear axle out of? Ratio?
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
#50 |
Thanks, Rear axle is an Eaton HO72, 5.14 ratio, out of a '67 Chevy Cab & Chassis truck. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-23-2023 at 02:46 PM. Reason: Added Ratio.... |
| Bookmarks |
