03-19-2022, 10:21 PM | #26 |
Re: Standard seat... dreaded broken spring
It worked surprisingly well! I was worried that the replacement side spring was going to put too much pressure on my left leg, but that wasn't an issue and I did not have any discomfort on my drive back to Milledgeville this afternoon.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-20-2022, 02:10 PM | #27 |
Nice work, that should hold it for now and it looks much better. You'll have a lot more options with the custom seat frame. I used 2 of them for my phantom bucket seats.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
03-20-2022, 05:20 PM | #28 |
Thanks! The biggest reason for wanting to change is the thicker foam and that I can get replacement foam too without having to cut my own.
