#26 |
![]() Join Date: Aug 2021
Re: Oil Filler Ext. Tube
Still available.
#27 |
ttt
#28 |
any idea if they work with a non-filler tube valve cover - meaning the special cut out to twist in a low rise filler cap. thanks!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#29 |
Yes they will work, you just need the grommet to put in the valve cover.
#30 |
ttt
#31 |
Still have them.
#32 |
ttt
#33 |
ttt
#34 |
ttt
#35 |
![]() Join Date: Feb 2001
This filler came on all power brake equipped trucks in 71-72. The booster stuck out so far that is was difficult to get an oil can to the valve cover. Fairly rare piece that would have already sold 10-15 years ago. Unfortunately, the LS swap craze has turned lots of people away from original parts.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
#36 |
![]() ![]() Join Date: Jul 2003
1969-70 K series had a similar setup, but with a metal twist on cap with a thick cork gasket.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#37 |
PM sent
#38 |
Sold to Casper 42. One left.
#39 |
![]() Join Date: Nov 2010
Still available? Do you happen to have the bolt for the support as well?
#40 |
No bolt just the oil tube.
#41 |
![]() Join Date: Jan 2009
PM sent.
72 Cheyenne C20 BB, air 70 Suburban 20 BB, air, buckets 68 CST C20 air, buddy buckets 72 Jimmy 2wd 72 Blazer 4wd air 4 speed |
#42 |
my easy restoration and install, for the one I purchased last month. Caps and grommet to valve cover easy to find online or at local auto-part stores
#43 |
![]() Join Date: Dec 2009
I will take the last if still available
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#44 |
Sold to jrstallion51. PM sent. Thanks Dan.
#45 |
![]() Join Date: Jan 2012
Looks nice! Did you have to swap valve covers to one with a smooth hole for the rubber grommet or were you able to use the one with the "special cut out to twist in a low rise filler cap" as you mentioned in a post earlier in this thread?
