Old 10-03-2022, 01:45 AM   #26
jjzepplin
jjzepplin's Avatar
Re: Syclone Killer
Looks good! Keep up the good work!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-14-2022, 08:17 PM   #27
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
So no updates, mainly been messing with the Lincoln and working. But for any S 10 owners with fog lights this may interest you. ironically I found one switch the day after I ordered the other, but on with the point. The switch with the very nice bezel had cut wires, so I ordered an NOS switch for an Astro van and robbed the actual switch part and viola NOS s10 fog light switch. Atleast now o have a not so purdy spare that I’ll never need.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 10-22-2022, 07:02 PM   #28
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Sometimes when life is too busy even the smallest things feel like an accomplishment. Only update is I got the truck in the garage and now I have the correct rear end under it.
If anyone has ever tried to find a factory 4WD 3.73 axle you know it’s not too easy, bonus it’s a disc brake rear with aluminum calipers to match my blazer dual pistons up front.
Old 11-12-2022, 10:58 AM   #29
68 TT
Still plays with trucks
68 TT's Avatar
Re: Syclone Killer
Great to see you back on this project. The disc brake rear end is pretty common but the 2wd vs 4WD issue is all climate dependent to your area. I have been looking for a 2wd one for quite some time but everything on my side of our state is 4wd for the most part due to the amount of snow we get so the rare 2wd one that comes up is stripped clean rather quickly.
I did something similar to your project using a Bravada as the donor inside and out. I made my S10 into an Oldsmobile Bravada appearing AWD truck with the upscale Olds leather interior. The plan was to turbo the 4.3 but I didn't get that far before I needed a bigger truck for work and it had to go in favor of my 1995 DRW K3500.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-26-2023, 12:32 AM   #30
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Yeah the disc and 4wd was the easy part, as you have experience with the bravada you may know this already. But the bravada and ZR2 are the only 4wd axles I’ve ever seen come 3.73 and posi.
Old 03-26-2023, 12:37 AM   #31
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Yes it’s been a while, between working 6 days a week, the cold, and upgraded the Lincoln to a 6speed auto, let’s just say I’ve had my hands full.
So anywho, for those that haven’t ever seen an LS7 clutch here ya go. The flywheel and clutch only go with each other as you can see there are raised pads for the pressure plate and speaking of, look at the thickness(mass) of the pressure plate. I didn’t have trans fluid laying around and it’s a lot easier to fill before installing so perhaps I’ll get that done tomorrow.
I did get the LS2 intake put on, took it off the Lincoln where I was using adapters and put the correct Ls3 one on it so there is another thing that had to wait.
Old 03-26-2023, 01:30 AM   #32
c10sport
c10sport's Avatar
Re: Syclone Killer
Sunbird cluster.
Do you happen to recall the number of that GT? I've been halfheartedly documenting them and wouldn't mind adding that to the junked list.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 03-26-2023, 12:17 PM   #33
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Originally Posted by c10sport View Post
Sunbird cluster.
Well technically not a sunbird cluster but they did start off as that. Redline is different.
Old 03-26-2023, 07:04 PM   #34
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
SomeTimes I hate living so close to Summit, other times I love it. Picked up a set of scratch and dent special Corvette rotors and pads. Guess that means it’s getting the big brake treatment
Old 03-26-2023, 09:36 PM   #35
c10sport
c10sport's Avatar
Re: Syclone Killer
Thanks!
Jay
Old 08-06-2023, 05:40 PM   #36
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
No updates per say. I’ve been fiddling a little at night when it’s cooler. Putting the Lincoln on hold for a bit since all that’s left is paint Really.
Anyways decided this will be my third vehicle with hydroboost.
Also acquired a ridetech 3 link for the rear suspension. So gotta back up a little before going forward. Kinda had no choice at $400 instead of retail at $1850.
And was given a K&N kit for a 18 and newer Tahoe which will work great for my air intake
Old 08-09-2023, 10:12 PM   #37
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
I’ll just leave this here.
Old 08-11-2023, 05:09 PM   #38
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: Syclone Killer
I don't see how it will help leaving it there. I would put it on the truck
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is online now   Reply With Quote
Old 08-11-2023, 09:51 PM   #39
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
All better now?
Proof of concept works, now I just need some 3/8 steel to make the adapters.
14” GT500 rotors with the stud holes opened up to 3/4”. And the hub bore size is within 1.5mm so I’m not worried about vibrations.
Old 12-22-2024, 10:11 PM   #40
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
So the project did not die. But between getting married, buying a new house, getting a real shop, building a leanto for the truck and trailer, shop heat and air, building the wife a 6.2/6L80 envoy, and some other stuff I’m sure.
I’m back to working on my stuff. Completely forgot about posting anything on the forum. But in the last couple of weeks I’ve installed coil covers on the front, to match the coil over and ride Tech suspension in the rear.
Front corvette rotors and calipers
Just got the low mount ac fitted tonight
Next is redoing my turbo hot side as I wasn’t happy with my hack job trying to finish before I moved.
Old 12-24-2024, 04:26 PM   #41
HO455
HO455's Avatar
Re: Syclone Killer
I take it the GT500 calipers didn't work out?
RIP Bob Parks.
Old 01-03-2025, 02:41 PM   #42
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
I never even tried GT500 calipers. The plan was always to use GM calipers.
The rotor was GT500 and that setup would have worked except for something so stupid I didn’t even think about. Caliper didn’t clear the wheels, so all 4 of the brembos are now on my Lincoln.
Old 01-04-2025, 06:41 PM   #43
HO455
HO455's Avatar
Re: Syclone Killer
Got it.
I think all of us have done that.
RIP Bob Parks.
Old 01-18-2025, 12:49 AM   #44
Myself
Re: Syclone Killer
First........congratulations on your marriage. I hope your wife is into the car scene as well. If she IS......well, me and mine been together 28 years now. Second, dang man, you and these crazy projects. I wish you lived closer LOL!! You going to the OBS nats/ Battle show in Talledega in June? Wife got invited to show her S10 on "Minitruck row".
Myself is offline   Reply With Quote
Old 01-18-2025, 05:52 PM   #45
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Nah the next place I go will be on a cruise. This project just hit simpler. Ditching the turbo setup and just going to get it finished up and driving.
My Cummins truck will be sold in two weeks to a friend when he comes into town.
And the turbo parts will be used on the C50 I’m picking up tomorrow
Old 01-19-2025, 03:26 PM   #46
HO455
HO455's Avatar
Re: Syclone Killer
Good to hear progress is happening. Driving it will be a hoot! How did the Ride tech installation go?
RIP Bob Parks.
Old 01-19-2025, 04:06 PM   #47
Madkidd007
Madkidd007's Avatar
Re: Syclone Killer
Better than I could have hoped. They don’t make anything for a 4wd chassis. I had to move the upper wishbone mount because the holes didn’t line up left to right and 2 tabs to bolt to the original shock bracket had to be shortened. Other than that it was nice.
Old 01-19-2025, 07:01 PM   #48
HO455
HO455's Avatar
Re: Syclone Killer
I'd love to see some pictures. I'm not completely satisfied with the drop springs and Caltechs on my Blazer.
RIP Bob Parks.
