01-01-2004, 01:56 PM | #26 |
Damn, I really should have kept that bad boy for myself!
01-01-2004, 09:20 PM | #27 |
Ok now tell me if I got this right ,I have a stock alternator setup.if I change it to a higher output one wire alternator I just need to bypass the external regulator ? I did this years ago on a 61 Chevy but my memory ain't good ,especially after last night
01-01-2004, 09:29 PM | #28 | |
you would have to ask a wiring expert...how to keep your gauges working????????? thats why i just used that little conversion kit(20.00)from frank PICKMUP.....AND installed that 84 camero internal regulated alt...all my stuff still works....if (never will) i wanted to go back just unplug the connector kit and reinstall the stocker.... hope that answers your question |
02-22-2004, 09:40 PM | #29 |
ttt
02-22-2004, 10:11 PM | #30 | |
Bloo
runnign both the ext and int regulator can also fry your battery, trust me, i boiled a brand new interstate battery
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
02-22-2004, 11:49 PM | #31 |
can running too powerful of an alternator be bad? i see summit has a chrome one that puts out 100 amps. is that too much?
70 longbed 496/th400/Ford 9" |
02-23-2004, 12:04 AM | #32 | |
My son, my joy.
No. MORE POWER IS NEVER BAD!!!! AAAH HA HA HA HA!! |
02-23-2004, 12:06 AM | #33 |
its all about the +6 inches
Well, there does come a point when you may want to beef up a couple wires in the system.
02-23-2004, 12:06 AM | #34 |
My son, my joy.
Also, they make kits for stock alternators that will bump them up to 95 amps or so for under 40 bones.
http://www.alternatorparts.com/gm_al...grade_kits.htm |
08-15-2006, 04:11 PM | #35 |
Re: ***omg...94 Amp Alt. On Your Trucks***
i know this is old but people keep asking...mines still running strong
08-15-2006, 05:44 PM | #36 |
The LuvShack Garage
Cool conversion
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-15-2006, 11:24 PM | #37 |
Low & Slow
I've had mine converted for a little over a year.. One of the best things I've done to the truck.. I converted after the ext regulator took a dive and burned up a big chunk of my headlight harness.. Lucky me nothing actually caught on fire.
70' C-10 LWB Fleetside 4.5/6 drop |
08-16-2006, 02:20 AM | #38 |
Mine is chrome and 135 amp!
08-16-2006, 07:18 AM | #39 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-16-2006, 08:38 AM | #40 | |
Where do these wires go after jumping the old connector? This is what I am referencing:http://www.chevelles.com/techref/tecref14.html Last edited by Jim_PA; 08-16-2006 at 08:44 AM. Reason: Added link to reference |
08-16-2006, 11:36 AM | #41 | |
Found it on Ebay from a good seller, 3 wire hook up... one ground wire, a positive wire , and one wire that plugs into the alternator itself. Was boxed up nicely with 135 amp stickers all over the place. |
08-16-2006, 11:42 AM | #42 |
King of Rust
Look here, http://www.madelectrical.com/electrical-tech.shtml I bought a 12SI and rewired everything using his products. You have to call him directly to order, but you just tell him what you are doing and he will tell you what you need and give you tech help. Great company!
08-18-2006, 11:35 PM | #43 |
On my concept one pulley system that i run on my 68 came with a 100 amp alt one wire set up. I am running a duel 13" fan set up, Air conditioning, high amp stereo, hela driving lights with the high beam conversion. I ended up rebuilding the 100 amp alt twice last yr. I installed all the good parts including hd bearings. It wouldn't keep up with the demand. I had a buddy check the amp draw and found out the fan assemble pulled 55 amps by themselves!!! Turn the air on at night with the headlights and it totaled over 105 amps!!!! I was literally burning it up. This was at in town rpm on the engine running at lower rpm. The bottom pulley is a 5" and the alt pulley was 2.25" Highway rpm cured it and the alt never dropped below 13.5 volts. Intown stoplight to stoplight and it was at 9.5 to 10 volts!!! Not enought rpm to keep the alt from charging properly. I contacted concept one and they were great, They built me a 6" lower pulley and i bought a 160 amp msd 1 wire alternator. Now at 900 engine rpm the alt charges at 12.5 volts. As soon as i hit 1000 eng rpm the alt jumps to 13.5 and stays there. I can now cruise around town and have the stereo on and air and not worry. When you start loading up on all these electronic items the amp draw goes tru the roof. Find some one who can check your amp draw and you will be surprised.
08-20-2006, 10:47 AM | #44 |
8 vehicles only 4 that run
I checked on the high amp alternators when I went to work last night (Advance Auto). The 94 amp is on the 84 Z28 Camaro, but there were two different vin codes for two different 305's, one had the 94 amp alternator, the other didn't.
I also checked some other models that year to see what others had for Alt's. The corvette 350 had a 103 amp alternator, and the adjusting ear on the alternator is threaded on that one. You could just use a bolt from the backside of the bracket screwed into the alternator instead of a bolt and nut on the non threaded ones. I've forgotten the exact prices of each, but I think the 94 amp was around $75 and the 103 amp was around $95.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
12-29-2006, 06:31 PM | #45 |
to the top for the new guy's
mines still going after 3 years |
12-30-2006, 10:48 PM | #46 |
Cool. Thanks MikeT for the alternatorparts.com link.
I was just wondering how I would be addressing the inevitable low amperage issue when I install A/C and a big stereo system in a few months. Nice to know a $55 parts upgrade to my alternator will save me from buying/trading up to a larger alternator.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
12-31-2006, 10:57 AM | #47 | |
You stereo guys should be installing a capacitor if you are running subs. This fixes one issue of amperage, when your subs "hit" your capacitor will keep the juice flowing to your amp and not have your lights dim Is this conversion kit still available? I am looking into ditching the external regulator.... |
12-31-2006, 11:02 AM | #48 |
YES IT IS give frank a p.m. and he can get it shipped out right away..
it's only like 20.00 something bucks...no messing around plug in and go |
01-07-2007, 09:36 AM | #49 |
Just found this link on Chevelles.com It's relevant to the discussion and appears to be quite informative.
http://www.chevelles.com/techref/ftecref14.html
01-07-2007, 11:28 AM | #50 |
NOT REALLY BANNED!
A 100amp 1wire int reg alt from autozoo or summit is about $100 and a bit less hassle.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
