#26 | |
Re: Opinions on 6.2 diesel
My turbo is mounted and I'm working on all the ancillary stuff now. I had to take a "quick" break and do a timing chain on my Toyota, but I'll be back at it tomorrow. That turbo manifold got all of Carlin's 7 dirty words during its install. |
#27 |
#28 |
I was working as the lube guy at a Pontiac/Buick/GMC dealership in the 80's. There was a customer that brought his rig in because it was 'knocking a little worse than usual' or something similar, but seemed to run just fine. Turns out the crankshaft was broken into two pieces, but were still interlocked somewhat!
I thought that was an interesting testimonial of sorts.
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
#29 |
![]() Join Date: Nov 2008
I've heard of things like this happening before . I guess its recommended to keep an eye on the harmonic balancer on the 6.2 engine , but also recommended to replace if not sure and to prevent possible damage . I guess to just to be safe ...
#30 |
I’ve had my ‘83 6.2L for about 13 years now and my dad has had his ‘84 6.2L for about 12 years. Both have been good, reliable engines. Some complain they don’t start well in cold weather, but we haven’t had a problem. Just like anything else, you have to maintain them. Keep good glow plugs and a correctly functioning glow controller in them and they start easily.
Bob Q. '83 K2500 6.2L |
#31 |
Moderator
![]() Join Date: Oct 2008
If you intend to put any serious miles or years on a 6.2 or 6.5 diesel it isn't a bad idea to put a Fluidamper on them.
The damped pulleys on engines equipped with them bear watching too.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#32 |
GM stuff is still available reasonably priced. This will be the second balancer, and first new serpentine pully since 83. I’ve know the truck since day one. I swapped it to serpentine in about 2000 when my best friend still had the truck. the 6.5 in my 93 busted the block, so we used everything off of it to put on this truck.
#33 | |
![]() Join Date: Mar 2013
#34 | |
#35 |
I’ve had good luck with the 60G’s as well.
#36 |
Moderator
The AC Delco 60G PTC glow plugs are the way to go.
I've been through three serpentine pulleys.
#37 |
I'll go back to the AC's then. Thanks for the input.
Interested in the resistor mod. I'm still counting on the factory controller to heat the plugs but every so often I feel it doesn't know what it should do and it creates a hard start. This typically happens if it has been run and then shut down for about an hour. It doesn't know if it should heat the glow plugs or not so it just flashes them on when it really needs more glow than that. I know people wire in manual buttons but that seems so intrusive. As a side note, in my opinion, the military 24v starting system works much better than the 12v dual battery civvy versions. It seemed my M1009 Blazers always started quickly while this van has always had a slower spinning starter causing slower starts. Anyone else experience that? And just to add my thoughts on 6.2's again, I love them. They are just as peppy as a factory small block from the same era in my opinion. |
#38 |
Moderator
Pinout of the later glow controllers with the Metripak plug;
When Terminal D gets 12v ignition power the relay thinks cold start is enabled and the warm engine inhibit is defeated. You can extend the glow time by installing one 5Ω 2W resistor in the wire running to the glow plug current sense Terminal C. Two 10Ω 1W resistors in parallel would carry 2W current with a resistance of 5Ω Four 20Ω 1/2W resistors in parallel would carry 2W with 5Ω resistance. This is a fairly decent explanation of parallel resistors. https://www.omnicalculator.com/physi...rallel-formula
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-19-2022 at 08:56 AM. |
#39 | |
Occasionally, my glow plugs will not cycle when the engine is warm, but it causes a slow/hard start. Last edited by 1972K20; 07-21-2022 at 11:32 PM. |
#40 | |
I have the van at my house currently and I ordered some new glow plugs a few days ago. Probably be lazy and start with those. Then I'll google Metripak so I can figure out what I'm looking for and go from there. Thanks! |
#41 | ||
Moderator
I've gotten an EVAP code on the way to the parts store when I dropped the gas cap down a storm drain but I've never fixed one by replacing or tightening the cap when the cap was present. Not impossible to fix it with a filler cap but very improbable. ![]() The 5 Position Metripak plug likely looks something like this only with wires. It may be Gray or some other color too. It's plugged into the glow plug contactor/relay You can see the cavity ID letters in the pictures posted below. A will have a cavity plug with no wire. **EDIT Removed the pull to seat six position female terminal plug image that was just kinda close to what you're looking for.** See the next post for the actual correct female terminal Metripak 280 five position push to seat plug.
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-22-2022 at 05:37 PM. |
#42 |
PN for the 85-93 glow plug relay connector is 12101871 and is a female version of the one Hatzie shows (no disrespect Hatzie, was piddling with mine and snapped a few pictures)
#43 | |
Moderator
Thanks for posting those pictures. The part number you posted is for the Metripak 280 repair pigtail. 12101871 is equivalent to Delco PT262 https://www.summitracing.com/parts/ado-pt262 The part number for the raw empty Metripak 280 Female terminal connector is in the GM wiring diagrams. Delphi Packard 12015982 https://www.mouser.com/ProductDetail...Ew0re52Q%3D%3D
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-23-2022 at 10:24 AM. |
#44 |
Thanks guys...I'm getting smarter with what you're posting.
Once I put the plugs in I'll look at the resistor mod and try to figure out what that entails. I know what I'm looking for now but will need to plan out how to install the resistor(s) cleanly next. I've had several 24V military 6.2's and must have gotten spoiled with the fast starts those systems give. This 12V system seems adequate at best so hoping this will help. Last edited by Willowrun; 07-23-2022 at 12:16 AM. Reason: u |
| Bookmarks |
