06-11-2022, 04:20 PM | #26 |
Re: Copy Original Pattern On Used Ring & Pinion Even If Not Ideal?
Hi PJ. Boy that's a lot of business, but you saved $1200 bucks.
The differential shop gave me a detailed break-in protocol -- several 20 mile runs, punctuated with 30 minute cool downs. Just running 3 miles to the supermarket and back won't do, they said.
06-11-2022, 04:25 PM | #27 | |
06-11-2022, 04:35 PM | #28 | |
Guys give you free stuff. Just pay shipping. Once, I sent some L6 Manifold hold down widgets to a guy in Central CA, and got stiffed on the shipping reimbursement, but I heard he got hit with medical issues, so I didn't get too bent out of shape. Other members have restored my Faith in Humanity. It's all good.
06-11-2022, 04:37 PM | #29 |
Agreed!
06-11-2022, 05:38 PM | #30 |
I _should_ go out and work on my Stepside project instead of goofing off on the internet inside under the swamp cooler, but it's 106* and Sunny w/ a 3 knot wind gusting to 6.
Actually, that's perfect spraypaint weather.
06-11-2022, 05:57 PM | #31 |
Sounds challenging to keep your sweat from dripping on the paint
06-11-2022, 06:12 PM | #32 | |
I may get arounf to it. At least shoot the Panhard Bar... After a bowl of pistachio ice cream.
01-26-2025, 06:31 PM | #33 |
Active Member
This thread was well-attended - I’m hoping for some knowledgeable recommendations on wear pattern for my 12 bolt.
In hindsight I should have put marking on it before disassembly but alas…. 3.73’s / Eaton Truetrac, new Motive axles. On install, I R&R’d the carrier a hundred times with the pinion depth scribed on the pinion, and just couldn’t get a pattern I liked with appropriate backlash. I added a 0.010” pinion shim, which pushes the pinion toward the carrier. I set backlash to its minimum (I honestly forget what it was, but I set it to the minimum spec expecting new parts would wear together and get me a little slop. It turns out the diff whines on acceleration at about 40-55mph, no noise on deceleration, no slop or “clink” when I tap the gas. I think it’s too “tight” either in backlash or pinion depth. The wear pattern looks weird too on the pinion, like spotted? Judging from what you see (and I can take more photos), what does your gut tell you? Thanks for any pro advice 😎 |
