Old 10-18-2022, 03:53 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Negative Battery Cable wire and Junction Block
Edited title.....
I never had the wire off the negative battery terminal, perhaps because it was a factory top post battery. I'm installing a side post battery.
I'm wondering where the negative cable's wire is supposed to be attached. Seems the fender is right, but? If the fender, my 72 is placed here, does that look right to you? Thanks
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
