#26 | |
Re: Sound Proofing/Deadening The Cab?
Thanks John
1965 C10 Long Bed Fleetside SBC 350 and Saginaw 4 Speed Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=838676 |
#27 |
Moderator
![]() ![]() Join Date: Aug 2011
It's a dense rubber/ashpalt type.
#28 |
I've given a bit of thought to wind noise and I notice that opening the vents or the OEM fresh air heater with windows closed will clearly increase the wind noise. I have strongly been considering installing at least one of those exit vents with the flapper check valve from the late models on the back wall of my truck. My Silverado for instance has 2 of them. I think without positive air flow, the incoming air is forcing itself out thru the felt covered channel around the side glass. (Which of course is right next to the occupants ears.)
#29 |
I used Kilmat from amazon. Reasonable cost and easy to install.
#30 | |
Good thoughts on the vents. The rubber seals on my kick panel vents are shot. I'm sure they are adding to the wind noise. I will put new vents on my to-do list. I hadn't really considered adding pressure relief vents. Has anyone here on the forum added these to their truck? Do we know how the vents impacted (better or worse) cab noise? Thanks. John
#31 |
I started a thread on it once but it didn't exactly take off. http://67-72chevytrucks.com/vboard/s...d.php?t=808699
Edit: you may want to make your own vent seals out of quality rubber. The ones I bought from a major catalog vendor were rotten after only a couple of years. Last edited by AcampoDave; 11-22-2022 at 10:42 PM. |
#32 | |
Thanks for the link to your thread. There are a couple of good ideas in there, especially the one about replacing the kick panel vent with positive air vents. I also like the idea of adding vents to the back edge of the door jambs. I've seen that on lots of 70's-80's GM vehicles. I never really gave those vents much thought until now. Thanks! John
#33 | |
#34 | |
![]() Join Date: Nov 2013
