#26 |
Re: Special tools
For handling wheels I use a long handled shovel. Lots of leverage with the handle, enough clearance to push down and a little shove and the wheel is on. |
#27 |
Re: Special tools
I have many "use once but worth every penny" tools. A valve spring, Crane, that was $100 20 years ago and now extinct but worth every penny. I have used it several times for swapping springs with heads on engine and engine installed.
Few homemade ones to...like this spark plug socket mod for getting plug in/out of that one cyl the header makes difficult. It slides on plug sideways and a open wrench to turn the cut down head to loosen, then just remove plug by hand |
#28 | ||
Re: Special tools
side rollers make lug alignment a piece of cake, especially timing duals.. safest, low effort option and they're cheap, roughly $50 - good luck! several versions of this type of wheel dolly but here's one example..
I started out with nothing - and I still have most of it |
#29 |
The Older Generation
Re: Special tools
I have never tried this but it looks like it should work.... Ball joint and spindle spreading much easier http://67-72chevytrucks.com/vboard/s...d.php?t=624464 LockDoc
#30 |
Re: Special tools
Handee Clamp. Used it a couple of times. No cussing needed.
#31 |
Re: Special tools
I needed a holding tool for the balancer on my daughter's Subaru. I was going to weld one up (they list for over $50 on Amazon, and who's got time to wait...) but then I got smart. I grabbed a piece of 1" square tube off my metal pile and drilled two 3/8" holes in it and ran 2" bolts through the holes. It worked like a charm. I threw it aside in case I ever need it again.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#32 |
Re: Special tools
LS engine tools. Balancer removal and install tool. Valve spring removal tool. Timing cover alignment tool. Oil pump alignment tool. Push rod length checker.
#33 |
Re: Special tools
Following up, I saw this on TV this morning. Sema new tool award winner. But, a little expensive for me.
https://www.liftwithtrac.com/pages/t...mance-features https://www.liftwithtrac.com/products/trac-tire-jack |
