02-15-2023, 01:25 PM | #26 |
Post Whore
Re: No start issue
I have already checked pin/wire location and continuity from what psi sent me
This is what I got from them And the are correct going by this --- Here is the wiring, check all three wires for continuity BROWN TO BLUE PCM PLUG 73 PINK TO BLUE PCM PLUG 61 RED TO GREEN PCM PLUG 39 PLUG LABELED A,B AND C ----- But i needed to know which of the 3 is signal wire... And I agree , I need all the help I can get..haha
02-15-2023, 03:36 PM | #27 | |
Re: No start issue
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
02-15-2023, 04:24 PM | #28 |
Post Whore
Re: No start issue
Thanks..that does help.. I saw several pics like this, but they were all diff wire colors and pin functions..
02-15-2023, 04:31 PM | #29 |
Re: No start issue
^^^^^^^^^ I agree^^^^^^
{EDIT} I don't know how my post ended up this far down the thread.. I intended it to appear as post #26, right below Acelo's post #25.. Last edited by RustyPile; 02-15-2023 at 05:49 PM. |
02-15-2023, 05:42 PM | #30 |
Post Whore
Re: No start issue
Pin C..red..has 12v with switch on
Pin A...brown...has 12v pulse while cranking So cam sensor is working.. And I've got 12v pulse from crank sensor while cranking So crank sensor is working.. Sighhhhhhh... I'm bout ready to burn it to the ground
02-15-2023, 05:55 PM | #31 |
Re: No start issue
Where did you take these readings?? You should check Both signal wires (cam sensor and crank sensor) at the ECM plug.. This will determine if the wire has continuity..
02-15-2023, 06:02 PM | #32 |
Re: No start issue
I hate wiring also.
So is it maybe time to put it on a trailer and take it to some one with HP Tuners? They should be able to see what is working and what isn't. |
02-15-2023, 06:42 PM | #33 |
Post Whore
Re: No start issue
Rusty, I did check them at the ecm plug...I backpinned the wires there.
LS, I agree.. thats probably the next step.. I've got alot of putting together before it can leave my shop though
02-15-2023, 08:43 PM | #34 |
Re: No start issue
Have you discussed with PSI the possibility of a defective harness?? Since the ECM will run in another vehicle, the problem almost has to be with your vehicle..
Something is preventing the ECM firing the injectors.. Sounds like the ECM is "seeing" a wrong feedback somewhere... Pick a shop that has the experience working with these type issues and possibly one that has experience tuning (modifying) GM engine management systems. |
02-15-2023, 08:56 PM | #35 |
Post Whore
Re: No start issue
Yep
02-15-2023, 10:10 PM | #36 |
Re: No start issue
On my first LS swap a 79 Camaro I brought it to the chassis dyno tuner with no doors, no front sheet metal, no glass and the radiator support just kind of hanging on. It was a pretty basic LS1 swap but it allowed me to drive it after the tune so I could get it to the muffler and alignment shop. Took it back later to the tuner for a few touch ups on the trans shift points.
02-16-2023, 08:53 AM | #37 |
Re: No start issue
Did you double check the cam sensor wires and/or crank wires to see if they are in the correct location? If they are crossed, you might have an issue there. I saw it on another forum where his harness from PSI had the cam sensor wires crossed and it would not start.
Just a thought. |
02-16-2023, 10:01 AM | #38 |
Post Whore
Re: No start issue
I checked the wiring pin location once....but I havnt doubled checked it..
But I will The tuner guy said hes seen 3or4 harnesses in the last yr with wrongly pinned plugs
02-17-2023, 08:21 AM | #39 |
Re: No start issue
If I read the story correctly, the wires were crossed at the sensor, not at the computer. I had that happen once on a LS3. Two of the wires going into the MAP sensor were crossed. It wouldn't start.
04-19-2023, 12:53 PM | #40 |
Re: No start issue
Any updates?
04-19-2023, 05:09 PM | #41 |
Post Whore
Re: No start issue
no... i put cranking on the backburner to try and get my painting finished..
ive got a tuner guy thats gonna look it over when i get ready
05-15-2023, 10:07 PM | #42 |
Re: No start issue
What's the latest on the no start? Any progress?
05-15-2023, 10:33 PM | #43 |
Post Whore
Re: No start issue
Still trying to fix my primer disaster..
