03-21-2023, 09:15 AM | #26 |
Re: So I drove through some water...
I ran a '55 1st Design for a while, after wrecking my '69 Power Wagon and before buying a '71 K/20. It was an all original barn fresh truck, so still 6v. I ran that everywhere and anywhere. It didn't crank so fast so I kept a 12v battery on the passenger floor. Battery cables were hooked up to the under floor 6v battery and I'd hook them to the 12v to start, then unhook. Worked like a charm. Didn't use the starter long enough to burn it up. That think started but quick, too!
03-21-2023, 09:25 AM | #27 |
In my prior life I rebuild many a transmission that "I just drove through some water".
Automatics don't take it for long. The friction material comes loose from the steel backing. Looks like it was never attached when you take them apart. Keep the water out and the vents connected and you will be ok. |
03-21-2023, 04:30 PM | #28 | |
03-21-2023, 08:47 PM | #29 |
The core of many great groups & music, ey? Happy to know we share the appreciation. I do relate to that song. I really was not born to follow. I do put effort into blending in. No man is an island and all that jazz
03-24-2023, 01:09 PM | #30 | |
My thoughts on 4wd...
FWIW, I have yet to figure out why somebody would buy a pickup that isn't 4wd. I've owned a vehicle with 4wd capabilities since the mid 90s when I could first afford one. I have yet to go "off roading" though there have been hunting trips on 2 tracks in the mountains of Wyoming and logging roads in northern Minnesota where folks might consider that off roading. Pro tip: Use 2wd until you can't. If you get stuck already in 4wd, you may have to work to get out. I use my truck to plow my driveway in the winter. I shift the transfer case into 4HI in November, and back to 2 in March or April. It is looking like April this year. Pro tip: Put chains on your front tires. You get extra traction AND you can steer. I have 3 daily drivers. One for me, one for my wife, and one for my college kid. All have 4wd capabilities. My driveway is uphill and gravel. I can't plow it clean. Snow builds up over the winter. From about the end of January until nowish you can't get out of my yard with 2wd. Many have tried. Let's just call it 1.5 months you need AWD or 4wd to get out of my driveway. That is 12.5% of the year. That is all I'm going to say about that. Quote:
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-24-2023, 02:06 PM | #31 |
20' Daredevil (Ret)
^^^ I can relate. My first and only pickup is my K20 that I bought in 1977. 2WD was never even considered. My driveway is not like yours, but with snow the short steep hill to my house will stop pretty much any chained 2WD. I once barely made it up with our old Grand Cherokee -- can't recall what the tires were but I'm guessing not the best.
03-24-2023, 04:03 PM | #32 | |
Proprietor of Dale's Corner
x3
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
03-24-2023, 10:16 PM | #33 |
Makes you wonder why, before the major automakers offered a 4wd, why companies like NAPCO, Marmon-Herrington, and Howe offered 4wd conversions and why any buyer would go through the extra wait and expense to have 4wd. Then why GM started offering NAPCO conversions through the dealerships, then began offering them in their line-up... back when only so many people saw the value. But the word on that spread until the market caught on, to the point that we have today more 4wd trucks sold than 2wd. It's as if they are a good idea.
As far as lifting trucks and putting taller tires on goes. Oh I don't know, consider farm tractors. I wonder why the rear drive tires are so much taller than the front. Traction on loose footing is more about engine speed and gearing and much less about HP. When I put taller tires on my first 4wd my truck did what the others couldn't do. A huge improvement. You can't put taller tires that make a difference on without creating more body clearance, by enlarging the openings and/or lifting the truck. Going from 30-31" tires to 35-37" tires yields 2-3 addition inches of differential clearance. And the taller the tire the bigger & deeper the lugs with great separation of lugs for better clearing of the mud picked up. Yes, there is a reason other than looking tougher. The reason is enhanced performance for what the truck is designed to do. I was the first guy around who ran tires over 32" and the few who also had 4wds back then were amazed by what my truck could do. I still remember what a noticeable change that made
03-25-2023, 02:03 AM | #34 |
All have valid points for people that need and actually use the 4-wheel drive.
The housewife in Tucson likely has 4 wheel rig and never in the life of the truck actually needs it. For her it would be a waste of $ used to purchase the rig and the extra fuel it uses because of the extra weight. My guess it way more fall into this category than the actual "needs it" category. And like you said their is a lot of them. My point is, more what them than need them. As of April 2020, 50.8% of new vehicles sold in the 2020 model year have been equipped with four wheel drive. If trends hold, four wheel drive will represent more than 50% of the market for the first time ever. The average transaction price of a full-size pickup truck was $60,289, up just under 9% from 2021. Of course the addition of 4 wheel drive has driven the average price up. |
03-25-2023, 06:44 AM | #35 |
What you say is true, except 4wds really don't use much if any more fuel than 2wd these days. I see it as a case of better to have and never need than not have the one time it's needed. If fuel consumption was a true concern, than that statement would be partially negated. There are so many added features I could say are not needed that are added to vehicles, driving their price up, I feel that exceeds the increase in added front drive system, especially when that is most common (keeping the build cost lower)
03-25-2023, 12:45 PM | #36 |
Some very good points made by all. Most all of my extended family has four wheel drive trucks. Since I have a SUV with four wheel drive I saw no reason for it on my truck. A personal decision. It has it's advantages, since almost all the trucks from the early 2000's are extended cabs and four wheel drives it makes my Standard Cab Short Box rare. I get offers all the time for more thank I paid for it over 20 years ago. Good conversation. Thanks to all that contributed.
03-25-2023, 06:41 PM | #37 |
I feel that most people would be just fine without it. In my area I was ahead of the curve and now that the idea of the benefits of 4wd have been absorbed by the masses my very nature pushes me away from what "they" do. 4WDs are in my blood, so I'll always have at least one. I just can't live without one . And I do plan to live out my years in the mountains in a rustic lifestyle, more so than I do now. But I don't do new construction on muddy jobsites anymore and feel I'd like to be the guy with a 2wd work truck now. I've had quite a few 2wd 67-72s and a few squarebodies, too. Both for work and play. When counties started cracking down on getting mud on the streets for sediment control concerns, I set up a '78 C/30 Dually for work and stayed on the street. Plus I got more into home improvement. Then I built a '70 C/30 DRW. I worked out of a '71 C/20 for a while, too. I'd love to have another 71/72 C/20 set-up for work to show the boys the other side of the coin they never looked at.
I'm driving a 2wd Sonoma presently and did some work for my sister who lives up a steep grade on a mountain. They both use 4wd daily to get up and didn't think I'd be able to get up to their place. I managed just fine. It just takes some driving skill. I've always used 2wd in my 4wds and they've lived there since '96. Been up that hill kore times than I can count. but many people can't get up that hill to the rental cabins. City folk, ya know
