#26 | |
Re: Thoughts on Gen 5 Vintage Air Install
Thank you so much!!
"If it ain't broken, fix it 'till it is!" |
#27 |
![]() ![]() Join Date: Jan 2005
I ended up replacing the Vintage Air center A/C vent assembly with an OE one so that it wouldn't interfere with the radio case. I epoxied the Vintage Air cap and duct adapter to the OE vent assembly. Couldn't get the duct on with it installed in the dash just like before, so I had to pull it all back apart, attach the duct, and reassemble.
#28 |
![]() Join Date: Jul 2000
I think you got the "SureFitsPoorly" kit instead of the "SureFit".
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#29 |
#30 |
![]() Join Date: Oct 2020
I like the look of the factory air set-up...but I was looking for a cheaper, but unique system to use for my A/C. I like the center vent, but it would be really hard for me to cut into a nearly flawless dash.
You did an amazing job with your A/C, Bravo! I on the other hand cheaped out and installed an under dash unit. The unit I installed was a new old stock, still in the box ACME unit I picked up from a guy who was going to put it in his C10, but sold the truck before he did. Here are a few pics. The good news is I get my full glove box. Last edited by 68 C10 Driver; 08-25-2023 at 09:20 PM. |
#31 |
Who Changed This?
![]() Join Date: Jan 2013
^Somebody has himself an awesome beard!
#32 | |
#33 | |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
It is 100% tight back there with AC & Radio, if I ever have to go back in there it will be WAY to soon! So, about the cap... I seem to recall something about replacing that tube where one end is capped. Seems the theory is when both being feed they more or less cancel each other out. So when you use one that is capped, you get more air and free up space (because you only run one hose). Thoughts on just running one line with that center tube capped?
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#34 |
#35 |
Mr. Cheyenne
Can't recall to be honest how they went when I replaced the hoses (wasn't fun either).
I found where I heard about that - it was a random video for Brother's https://www.youtube.com/watch?v=TjY3...HERSTruckParts Edit: Looks like the video is correct, there are two separate lines going to the center outlet.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 08-26-2023 at 11:18 AM. |
#36 |
Barely enough room for all those vent hoses without doing some creative packaging! I've got some in my truck hanging by large zip ties. No vent hoses is another advantage that under-dash units have.
A friend of mine who is doing a 1973 'Cuda is keeping his heater/defroster system intact, and using an under-dash unit from Old Air. I'm looking forward to seeing how it works. It's similar to this: ![]() Back in the day I had two cars with aftermarket under-dash units, and I don't remember having any problems with them. Of course, you have to give up the outlet to the left of the steering wheel that blows air on your face. But I was much less demanding back then ![]() Cool intro here to a book about early automotive AC systems. https://macsmobileairclimate.org/201...-conditioning/ ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-26-2023 at 12:12 PM. |
#37 | |
#38 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#39 |
![]() Join Date: Feb 2002
Swell write up, Pat. But is it totally necessary to remove the stock Heater Core from the engine bay?
#40 |
#41 |
![]() Join Date: Dec 1999
Airflow is most likely better on center vent with a single inlet as long as the larger duct is maintained from the source. The outlet pressurizes and distributes the air. With the stock configuration of two inlets blowing towards each other create more turbulence and airflow is diminished. Just capping the factory vent creates some problems because of the design. There are some aftermarket replacements that taper appropriately.
One of the things I do not like about the compact aftermarket systems is that they use smaller ducting. Smaller ducts create high velocity versus higher volume with larger ducting. I assume the fan in these systems has the ability to overcome the static pressure created.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 08-27-2023 at 02:39 AM. |
#42 | |
#43 |
Sounds like an under-dash system is made for you.
#44 |
I have a Production A/C optioned truck. ['71 GMC Jimmy 4x4 K/1500 Deluxe trim] The OEM air components were stripped, over the years, so I'm starting from Square One or Two. As I live in the Desert South West, I'm looking for a High Performance Air Conditioner.
Under Dash would be great in my Orange Stepside -- if I could source 292 A/C Compressor brackets. But the Jimmy cab already has the factory A/C ducting. And being a 'two door station wagon' [according to AZ MVD] has about 2-1/2 times the cabin volume of a pickup.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-28-2023 at 07:05 PM. |
#45 | |
In one of the photos it looks like you are running the cable conversion sensors, did those come in the kit?
1972 GMC k20 suburabn - on instagram @c10suburban |
#46 | |
#47 |
You got the compressor hoses to look pretty nice. On my IV kit, I ended up getting new hoses made so they didn't look like spaghetti. I wondered what fit/orientation they were going for, of if my ends were just crimped on at different orientations that they should have been...
#48 | |
#49 | |
So I took some images from my build post here: https://67-72chevytrucks.com/vboard/...=815278&page=9 and starting with Post #220 this was what I did to modify the inside heater box. Last edited by 68 C10 Driver; 08-31-2023 at 02:34 PM. |
#50 | |
I was at the Old Air factory in Fort Worth several weeks ago. Like V/A, they use the rheostats attached to the OE levers, but also have an electronic panel designed for our trucks that I think looks nicer than V/A's. It's personal preference, but I would choose the electronic panel instead of using the rheostats. That plus the electronic panel has a much shallower depth.
