#26 |
![]() Join Date: Mar 2015
Re: Move the gas tank or no?
Here is a picture of what I ended up with after a long drawn out deliberation.
It's a reversed Blazer fill. Fills like stock, no burping required and it's easily accessible for filling. Picture was taken before it was screwed down and painted to match. |
#27 |
Yeah, fuel tank in the cab was safe all the way to 72.
Also, 7 out of 10 doctors prefer marlboro cigarettes , lead water pipes are safe, knob and tube wiring isn’t dangerous, mercury is ok to play with in your bare hand, asbestos is a perfecty safe and useful product… etc etc |
#28 | |
Who Changed This?
![]() Join Date: Jan 2013
I worked for three Chevrolet dealers in the early '70s. Another problem that I remember was when there was a recall on Buick Opels. The windshields would pop out when the vehicle rear-ended another one. Turns out that the assembly line workers were greasing the windshield seals instead of installing them according to the instructions.
#29 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#30 | |
![]() Join Date: May 2012
![]() j
White K20 |
#31 | |
![]() ![]() Join Date: Jul 2003
![]() Quote:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#32 |
About the tanks and explosions.
Have you ever seen an explosion and thought, if i were only 6-8 feet from that explosion i'd be safe? The kill radius of a grenade is 10-20 meters. I can guarantee after throwing a few that you won't feel safe at 21-35 meters. Point being, if you drive a gasoline powered vehicle, you're firmly and securely INSIDE the kill radius of the tank exploding, regardless of where you put the tank. |
#33 |
Good point on the radius. It would theoretically take a much greater impact to have a puncture and possible subsequent explosion with the in cab tank. The weakest most vulnerable part of them is the neck getting ripped off.
#34 |
I was in a VW that caught fire. It had a full fuel tank.
It just leaked out and burned, like any other fire. It was exciting, as I hurt my knee when I bailed over the guard rail. The fire department showed up 20 min later. Nothing left but no explosion either. Sometimes the gas tank will rupture and the gasoline will ignite. That gives a pretty good fireball but it really isn't an explosion. The gas tank won't explode like a propane tank because it is designed to rupture before dangerous pressure builds up inside. Bear in mind that under normal circumstances the pressure in the gas tank is basically atmospheric. The only way to make a car explode like you see in the movies is to put a bomb in it. The idea is to not have this fireball in the interior. Now we can move on to EV batteries and the fires they cause\. Last edited by Accelo; 08-24-2023 at 08:33 PM. |
#35 |
![]() Join Date: Apr 2016
Well darn it, if I can't go up in a big satisfying explosion like in the movies using stock parts, I'll have to look for some aftermarket explosives to sandwich between the tank and seat back...
#36 |
![]() Join Date: Dec 2017
For nearly 20 years I was a volunteer firefighter, and fought many vehicle fires, and I never witnessed even one vehicle actually explode. Several leaking fuel lines, and a few punctured tanks (none were in cab tanks that I can recall, most were cars with rear fuel tanks). One of the most memorable was a pontiac which flipped over at high speed, and caught fire in the middle of a highway upside down. After it was extinguished the tank had swelled up to about twice it's original size, but again...no explosion. While many believe vehicle fuel tank explosions are common, I have yet to see one, and believe they are probably rare. YMMV.
#37 | |
#38 |
Junior Member
![]() Join Date: Sep 2017
Leave it. Unless you are building a show truck or autocross style, it's not worth it. I have built an autocross truck from the ground up and relocated the tank because it was the trendy thing do. The original location is fine. It's extremely easy to work on and parts are cheap. Also, you do not have to fab up a system to fill the tank unless you just cut a hole in the bed, but why would you want to do that. I suggest fixing the fume issue and driving the heck out of it.
#39 |
Yeah, tank under back near exhaust is right up there with the 71 Pinto I owned.
I'm good with carburetor, and having tank above fuel pump is more efficient, why they start so dam good. |
#40 |
![]() Join Date: Feb 2003
I Like STOCK, restore the hoses and seals
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#41 |
I probably will in the rear coils!
#42 |
I moved the tank outta the cab for a few reasons:
-room for speakers/subwoofer. (I’m 54 and still like it loud) -no stinky fuel smell. -more weight to help lower the rear a bit more. (With a full tank) -better weight transfer for racing. -better traction, for racing. -makes room for different seat options. -running an in-tank fuel pump, you can’t hear them at all.
"If it ain't broken, fix it 'till it is!" |
#43 |
I'm totally onboard with Extended Power, moved it for traction and an attempt at chassis balance. It wasn't too expensive using a Tanks Inc. universal tank and I cut a door in the bed floor sheet metal with a Dremel. I have heard nothing but compliments on how nice the truck rides and I believe moving the weight back really helped that.
#44 |
I've never had any "venting fumes" into cab issues, or concerns on my three C/K's - if you are there's something else going on.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#45 |
![]() Join Date: Dec 1999
Waking up hanging upside down by my lap belt after being knocked out cold, with gas dripping in the cab was all the reason I need to move it and add three point belts. Not building a 100 point stock resto show truck, I am building a truck that will be my main daily driver.
Edit- See some talking about explosions. A fireman saying they are uncommon. If would have died in an explosion that would be better than being burned alive with the accelerant leaking in the cab. Some have pointed out things are done differently with time. There is a reason for that. If you choose to ignore, that is your choice.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 08-28-2023 at 04:07 AM. |
#46 | |
![]() j
White K20 |
#47 |
Uncommon is actually non-existent. I've seen many automobile fires. The gasoline simply "fuels" the fire, as if one putting lighter fluid on a camp fire. There are "pops" and such, but far, far from anything like what one sees in television.
#48 | |
BTW, probably the worst fire I witnessed involving a vehicle was the result of a mechanic working on the plumbing to dual tanks on a mid 70s square body truck. He was using a trouble light (the old style with a bulb), and raw fuel hit the hot light bulb, which exploded, igniting the fuel. Those working in the shop were unable to extinguish the fire in a timely manner, and the dealership was a total loss, along with several vehicles in the shop, and new cars in the showroom. Last edited by chevmn; 08-28-2023 at 01:20 PM. |
#49 |
![]() Join Date: Jul 2000
I don't remember smelling gas in the cab during 34 years of driving my 69 C10. However, I have smelled gas fumes in the garage due to the vented filler cap. But it only seems to happen after a drive. Gotta come up with a solution to that some day.
As for the tank behind the seat, I think it was a bad idea. But probably not as bad as a Pinto tank near the rear bumper!
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#50 |
I'm on the fence with this myself. The "project" I recently bought already has one mounted under the bed but has the filler in the floor which will be a pain to fill as you have to stretch over the bed side or tailgate to reach it. I'm also concerned with water getting into the tank from rain or melting snow. At this point I'm considering going back stock with everything new. The gas tanks on my motorcycles are pretty much in my lap. I try to be a careful driver, but you can't drive for the other person.
