Old 06-17-2024, 01:58 PM   #26
Mav
Mav's Avatar
Re: 1971 K/10 longer front wheel studs?
Put the 610-156 stud on and it works fine, actual knurl measures .562-.563, actual on 041 IS .561 (on all these I have). so close as I could get on that. Ended up getting 12 1/2 turns on threads which satisfies the 1 1/2 times stud diameter rule, anyway Im happy with it. (Your actual results may vary, lol). Thanks kw and all who contributed!
Mav is offline   Reply With Quote
Old 06-18-2024, 05:18 PM   #27
mr48chev
mr48chev's Avatar
The oem style studs do have the knurl in a not what you would think position.
This out of Rock Auto.
My ongoing truck projects:
Old 06-18-2024, 09:23 PM   #28
Mav
Mav's Avatar
Size:  18.5 KBHere is what the factory put on my pickup.....
Old 07-31-2024, 08:52 AM   #29
CUSTOM/10
CUSTOM/10's Avatar
I'm currently having the exact same issue.
Check out Dorman 610-130 these are very close .
.56 knurl in about the correct location, 2" under head length,
Just the shoulder is about 1/4" longer. But I don't think will be an issue due to the rim thickness. I bought one yesterday and plan on doing a test fit soon.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-31-2024, 06:33 PM   #30
CUSTOM/10
CUSTOM/10's Avatar
These work !!!
The knurl is almost all in the hub, the shoulder does stick out about a 1/4" but the rim hole size & thickness covers it and I got about 14 threads on. No drilling or modes with the M/T Classic 3 rims. They are a tighter fit to press in and I used a hydraulic arbor press.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
