#26 |
![]() ![]() Join Date: Jan 2005
Re: Decals for 8000 RPM Tach and Vacuum
#27 |
I also have regular 5k tach decals available.
#28 |
![]() Join Date: Aug 2018
Second shipment arrived safe and sound, good work!
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
#29 |
#30 |
Will do, I’m building an extra set of gauges with the s10 speedo conversion for a Ls swap. The stencil for the conversion is a paint type and is the reason I was asking about that on the other post. I’m excited to see how it turns out and glad it will be in the correct font
#31 |
How did I get this OLD!
![]() Join Date: Dec 2014
The decals arrived today. Just have to dig out a lens and polish it up.
Thnx again. Michael
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67. |
#32 |
#33 |
![]() Join Date: Aug 2004
I'll take an 8K tach decal if you have any
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#34 |
#35 |
#36 |
Here's a video that shows how to install a tach decal.
https://youtube.com/shorts/QPzylsrfP-w?feature=shared |
#37 |
I have these automatic tilt column shift indicator decals to offer. They are modeled off of the text of a factory indicator (NOS and van text are different). One style is the stock layout with PRNDL2L1, and the other style is PRNDM for use with a modern transmission such as the 6L90E that has a "Manual" mode.
#38 |
![]() Join Date: Dec 2009
Very Nice
![]() ![]() These will Update an Updated truck. Nice job. ![]() ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#39 |
DND Trucks
![]() Join Date: Dec 1999
Patrick,
I'd like to get 2 5k tach lens decals and 2 vacuum lens decals. Also, do you have anything for the vacuum gauge and tach faces? Thank you |
#40 | |
https://www.whitegauges.net/products...ce-Gauges.html |
#41 |
I would like to purchase a 5k tach decal, and a vacuum decal, please. Thank you!
'72 K20 |
#42 |
#43 |
#44 | |
DND Trucks
#45 |
#46 | |
DND Trucks
Decals arrived today and look absolutely perfect. Thank you. |
#47 |
#48 |
![]() Join Date: May 2008
OMG this is a life saver I'm building restmod and it's running a supercharger and I wanted a boost gauge give me couple of days to get my gauge cluster out and see what's what but I'm interested for sure
#49 |
#50 |
Are the repo tachs at Summit any good?
| Bookmarks |
