Old 04-25-2025, 01:00 PM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Reproduction Single Wall Top
Originally Posted by Rickjz View Post
How hard would it be to switch from double wall to single wall top?
Easy, if you have a 72 with provisions to accommodate a single wall. Some (many?) do.
Old 04-25-2025, 01:07 PM   #27
preciador6
[quote=Blazerowner;9295445]Just found this. Same maker?
https://tuckersparts.com/products/blazer-top[/quote 11k?
preciador6 is offline   Reply With Quote
Old 04-25-2025, 01:57 PM   #28
Rickjz
I have a 71.
Rickjz is offline   Reply With Quote
Old 05-03-2025, 02:54 PM   #29
Piratenation
New Member
Piratenation's Avatar
You will have to drill all new holes on your bed rails since the single wall tops have a different hole pattern. You will also have to weld new cage nuts on the underside of the rail where the new holes are unless you want to hold a nut and ratchet under the rail while you tighten the bolt from up top.
Piratenation is offline   Reply With Quote
Old 05-03-2025, 05:13 PM   #30
GSP7
GSP7's Avatar
$11,000 bucks ? geeze !... That's quite a profit margine
Campare to camper shell prices
https://www.dualliner.com/blog/new-t...KjHva6J8WPJZsH
R.E. – $1,499.00 for aluminum to $4,200.00+ for fiberglass
Century – $1,675 to $2,375
Jason / Ranch / ATC – $1,450 to $3,000
Leer – $2,179 to $4,199
SmartCap – $3,695 to $4,495 stainless steel
Snugtop – $3,000 to $3,999
Unicover – $1,395 to $1,950
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
