#26 |
Re: Coolant overflow bottle ideas
#27 |
![]() Join Date: Feb 2002
I have the Camaro/Nova style. It tucks in between the passenger side front fender and the battery box. But then it's not in front of the radiator bulkhead. It is tucked away, though.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-17-2023 at 06:29 PM. |
#28 |
^^^, I have that OER tank in my 67 Camaro. The tank is for a 75 Nova.
The only reason I didn't use it in my 72 (post 15) is because charcoal canister is there so used a Dorman one on core support. |
#29 |
Don't have a pic nor the truck anymore. You could audition something (piece of paper) in the area I put the tank to see if you can see it through grill. If so, it was never a concern I had.
#30 |
Anyone know the hose barb size for the Dorman 630-001? I cant find it and they definitely don't answer the phone.
#31 |
I just used the hose from radiator that was on the truck that otherwise was open and just used that on the Dorman barb. Put it through one of the holes, large, that was already in the core support
#32 |
![]() Join Date: Jul 2000
OER 551448 tank with Dorman 82590 cap. Had to use an "L" bracket to support the bottom.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#33 |
![]() ![]() Join Date: Jul 2003
The 551448 tank looks like the best option on these.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#34 |
Just keep in mind that I had to remove the battery tray (kind of a PITA) and then use an L bracket as a base for the tank.
The silicon hose I used is really nice. It's flexible and is fairly thick-walled. Rated to 460 degrees F. 3/8" ID x 9/16" OD. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 Ended up using some Dorman 13400 hose clamps I found at Autozone, but they tend to deform because they are not spring steel, like OE. Pretty sad, this imported crap.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 12-20-2023 at 12:34 PM. |
#35 |
Thank you for the information.
Only change I will make is using the coolant cap specified for a 1978-79 Nova, which is GM 371978. I think it looks more period correct than the later vented unit.
#36 | |
[But, I totally agree on Imported Crap.]
#37 | |
I think I referenced your photo a couple of times when doing the job! Thanks.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 12-20-2023 at 07:23 PM. |
#38 |
![]() Join Date: Jul 2001
For my recovery tank I used a stock w/s washer bottle& bracket. Mounted to P/S fender aft of the battery, run the hose to the radiator overflow vent. Pickup hose in the washer bottle works fine for the return line. Went with a closed system cap and keep it about 1/4 full when cold. Not very fancy and shiny but looks like it belongs there from GM
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#39 |
I used an overflow bottle from a Mitsubishi Eclipse. Wish I could remember which year it was from.
1968 SWB Step Side, Big Block, 4L80E , Running! |
| Bookmarks |
