#26 |
![]() Join Date: Jan 2007
Re: Previous owner '68
Good progress
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#27 |
![]() Join Date: Aug 2004
That Jack saves the day again! Perfect for doors.
I don’t know if it’s a better way, but it worked and didn’t require much from my back.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#28 |
![]() Join Date: Dec 2009
That is a Handy-Dandy jack.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#29 |
![]() Join Date: Jun 2002
I like it! Here's another project I did using a broken hose reel. It made a great cart for the plasma cutter.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#30 |
I decided to replace the cab mounts so I jacked up the cab for access.
#31 |
Which quickly turned into this. I think this is called the snowball affect. Yeap, using that jack once again.
#32 |
Yeah the snowball effect happens alot.
![]() Then when the Snowball melts you are going down the Rabbit Hole. ![]() Great progress. ![]() ![]()
#33 |
Thanks, it all takes time.
#34 |
I have been noodling on how to semi-safely remove the bed from my truck, in a single garage bay, by myself, with no special tools to speak of. I approve of your methods
![]() I'm thinking about some sort of block-and-tackle arrangement myself. OSHA, more cat videos for you guys!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED
#35 |
Also, now that I look again, I am very curious about what appears to be a 2nd-gen Firebird in the background of those bed-removal photos.
#36 | |
You got a good eye joeydurango. It's a '73 Firebird ( who will soon be identifying as a Trans Am).
#37 | |
...sorry, now back to the truck resto...
#38 |
Nice looking car, I'm a fan of the '76, the bumpers flow better than the '74-'75 and I am burnt out on black and gold 77-78's. At least you had 4-speeds, my 73 is a 350 auto.
I had a '73 Trans Am when I was in the Navy and always wanted another one but the prices were not something I was willing to spend. I found this '73 Esprit and have slowly been upgrading it to be what I want. It will end up a 400 4-speed. One more pic then back to trucks! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-08-2024 at 10:59 AM. Reason: Add pic |
#39 |
Very curious to see how the truck turns out.. And now the pontiac too lol
#40 |
You and me both!
#41 |
Agreed on all three counts! That's a nice-lookin' Firebird, should be a fun project.
#42 | |
A kid in high school had a Formula with the "nostrils", white with twin green stripes, and I loved it.....
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#43 |
I actually like the formula hood better than the TA hood, but the one I have has been abused. It looks okay but I have done a bunch of fiberglass work on it to get it to this point.
#44 |
I do too Jim, hopefully you can save it.
#45 |
Back to trucks! I threw some rollers on the rearend so I could roll it around easier. Ha! I'm an idiot, it's a posi. Rolls good going straight, not so good around the corners.
#46 |
Used the plasma cutter to cut Pacman out of the rear crossmember. Be looking for this on Facebook marketplace under "NOS 1968 Pacman - no lowballers, I know what I got"
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-08-2024 at 09:34 PM. |
#47 |
This had the added benefit of making a good place to run exhaust through in the future. I did finish the holes off by welding in some pieces of 4" pipe.
#48 |
I had to flip the frame to weld the bottom section of the cross-member exhaust pass throughs. Flipping the frame was fun and scary! While i had it flipped I cut it for a c-notch and painted the bottom. Should have taken more pics, but when I'm on a roll it's hard to remember.
#49 |
Then I flipped the frame (for the last time!) You'll notice that I removed the front cross-member, mostly to clean out the years of rust, grease, and mud.
#50 |
Now, I wanted to go five lug with this truck and I had the front cross-member from a '85 chevy truck that I decided to use. I know, I could have used the old cross-member and just used different balljoints and tierod ends but this is how I did it. If you are interested in the many different ways to do the drum to disc swap you should read this thread by lolife99. It says it all better than I ever could.
https://67-72chevytrucks.com/vboard/...d.php?t=444815 It was filthy. And I ain't gonna kid you, getting those springs out was a bear.
| Bookmarks |
