Old 01-05-2024, 08:33 PM   #1
Orange Crate
Orange Crate's Avatar
Hub Cap Removal Tool
I just had my Accuride rims powder coated and wanted to see how some stock hub caps would look with the new color of the rims (spinnaker white). I could NOT get the hub cap off (without scratching the rim). I spent a lot of time searching flea markets and swap meets for these decent hub caps (12" 4X4) so any more scratches or dents were not ok. It took a few minutes to come up with something to get them off without damage but here it is, it worked perfect and no scratches on the rims or caps. I have some 3/8" stainless rod to make exhaust hangers, so I used that along with a torch and a ball peen, added a small section of old hose at the pivot. The new tool needs to be applied as close to the "nub" on the rim as possible. I installed and removed the cap probably 15 times. I did notice on the rims that the four "nubs" are two different styles. It looks like two have a little more of a "hook' to them and then the other two are a little smoother to keep the cap centered. When I was using my new tool it worked best when applying it next to one of the nubs with the deeper hook. I have an original 72 eight lug rim and it also seems to have the two different type of nubs, but maybe I'm just making that up....idk. Enjoy!
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
